Best way to stop the body roll
nunii
nuni
florida
2025 honda civic type r
The car feels super stiff on r settings, but on high speed sweeping turns I get a lot of body roll. What is the best way to fix?
whtciv2k
raf
VA
Integra Type S
Lower center of gravity with springs or coilovers and Thicker sways.
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
Thick Rear Sway Bar, and if you're up for quite some labor then a Front Sway Bar as well. We just supplied a setup for a DE5, the customer's super happy with the setup!
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
I feel the body roll also when doing high speeds on banking on-ramps to highways.
On the track however, the car felt amazing. Didn’t notice any body roll at all.
Kinda weird actually.
Unity Performance
Humza
A more expensive but worthwhile mod so far to me has been the SDI e-CLIK suspension controller, which allows me to take over control of the dampers and I can confirm it's pretty much eliminated body roll. I also have H&R Springs and a 22mm Progress Rear Sway Bar, which helps but nowhere as immediately noticeable as active suspension.
DSC has a similar offering but without the screen so you need to hook up your laptop for changes to the software. I bought one of those as well to test out, and waiting for delivery and testing to weigh in on it.
Brief overview of SDI:
ModJPB
Jason
Lowering Springs and shocks will make the ride more harsh. Is this what you are willing to accept?
Sway bars do a far better job of preventing sway without adding to much harshness. Just do a larger rear bar and see if it that solves your problem.
If you do springs, choose ones that don't drop the car much. Aggressive lowering springs usually mess up suspension geometry causing effective center of gravity to increase which means more roll.
Shocks and struts affects how fast it rolls, not how much it rolls.
I added stiffer sway bars to another car and body roll was greatly reduced. However cornering traction went down since stiffer bars transfer more weight to the outside tires, unloading the inside tires. Especially noticeable powering out of corners.
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
Isn’t that a good thing for the track so you can turn in harder/faster?
lflouie
jeff
Knoxville, TN
Audi S4, Audi A4
You mentioned ordering the DSC controller, have you received, installed and evaluated?
Unity Performance
Humza
Stock CTR body roll is already near zero. Increasing swaybar thickness will stiffen the ride and transfer more load to the outside tires, which already do most of the work. Stiff swaybars also increase head toss, which I find anoying.
Stiffening only the rear bar may result in excessive oversteer. I've overstiffened the rear in past cars and found myself pointing the wrong direction too many times.
lflouie
jeff
Knoxville, TN
Audi S4, Audi A4
I fully understand your observations on using overly stiff sway bar settings (RV6 comes to mind in middle and stiff hole setup). I am looking for a slight 10-15% increase in stiffness to aid in lower speed tight corner induced push on turns. A Whiteline 22mm rear bar in the softest setting should help without creating other undesirable issues.
Don't get me wrong, I love this car, just looking for a slight tweak to address my driving situations.
I also have a DSC that I'll be installing next month, so I should be able to dial in the overall setup.....can't wait for the snow to be gone.
