CSF Radiator + Acuity Reverse Flow Coolant hose + PRL intercooler
FL5golfer
Anyone have this set up?
CSF Radiator + Acuity Reverse Flow Hoses + PRL intercooler
I am going to install these on my car and wanted to see if anyone has had experience with this setup at the track.
Thanks!
FL5golfer
FL5golfer
I had the opportunity to test this set up at Buttonwillow with ambient temps up to 95F last weekend. Unfortunately, the car ran into cooling issues. Coolant and oil temps were the highest I've seen and worse than before with stock radiator and intercooler
The first session wasn't that hot yet (around 75F) and the coolant temps reached 240F and Oil temps reached 290F after 4 laps chasing my friend's GR Supra. I was able to keep up with him until had to cool down for 2 laps, then picked up the pace again on lap 7. Heater was on but not full blast. The rest of the day, I had to run the heater on full blast during the next 4 sessions. As the day went on, ambient temps got hotter, coolant temps reached 240 and oil temps reached 280F. I still had to cool down after a couple of laps. I'm not too happy with this setup.
Car is on stock tune.
Only engine mods include:
1. PRL Intercooler
2. CSF radiator
3. Acuity Reverse Flow Hoses
4. Honda Coolant
5. Amsoil 5w30
6. PRL HVI Intake
Here are my thoughts and please comment if you have any feedback:
1. Plan is to put the stock intercooler back on. I think the the PRL intercooler is too thick and blocking the air flow to the radiator.
2. Hoping that the Acuity Reverse flow hoses are compatible with the CSF radiator. For those with PWR, I heard that they are not compatible.
3. Install an WOT Oil cooler which will help bring oil temps down and hopefully also reduce coolant temps since the motor uses an internal water to oil / transmission cooler.
Thanks for your feedback and input!
Here's my car in action at the track:
11th Gen Honda Civic CSF Radiator + Acuity Reverse Flow Coolant hose + PRL intercooler Jul-27-2025-Speed Ventures (Sun)-Red Group-Session 2 (Phil Hill)-CP1_5159_Jul2725_1019AM_Cali
11th Gen Honda Civic CSF Radiator + Acuity Reverse Flow Coolant hose + PRL intercooler Jul-27-2025-Speed Ventures (Sun)-Red Group-Session 3 (Sunset)-CP1_5993_Jul2725_1153AM_CaliPhoto
11th Gen Honda Civic CSF Radiator + Acuity Reverse Flow Coolant hose + PRL intercooler Jul-27-2025-Speed Ventures (Sun)-Red Group-Session 2 (Phil Hill)-CP1_4993_Jul2725_1011AM_Cali
FL5golfer
FL5golfer
Track day tomorrow again at buttonwillow. Weather forecast says high is going to be 100F.
Put the stock intercooler back on and installed the WOT HPT Cooling Plate to replace the stock undertray. Let's see what happens!
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
FL5golfer
FL5golfer
Hey Guys!
Sorry for the late response.
Changes I made this time around:
- Switched back to Stock intercooler
- Installed HPT cooling plate
Weather was hotter, cooling was improved with more airflow going into the radiator but car still overheats. At 75F ambient, the coolant temps get to 230F after 4 laps. No more summer track days for me. Going forward, I will just go during the cooler seasons of the year. Maybe down the road, I'll get an oil cooler. I'll continue to update you guys.
Anyone have the Acuity Reverse flow hoses? Noticed that coolant leaks a little bit at the point where the hot hose connects to the engine.
This is my PB of the day on lap 4 session 1
Hey Guys!
I used to have the Acuity hoses, but on a 1.5t and there was just initial coolant that dripped from when I changed the hoses, no leaking. Some did drip into a little crevice on the transmission I didn’t notice at first, but could smell it from the heat after driving. I also was paranoid of them leaking and tightened the hoses as much as I could.
Have you thought about getting an aftermarket thermostat as well? Like Hybrid Racing, J’s Racing or Spoon? Should open up at a lower temperature to help cool even more.
FL5golfer
FL5golfer
It's been a while since the last post. I previously said no more summer track days but I can't help it. I'll be at buttonwillow next weekend and temps will be 104F. It's going to be HOT so going to take it easy. This time, I have another cooling mod: a WOT single oil cooler. Will keep you guys posted!!
11th Gen Honda Civic CSF Radiator + Acuity Reverse Flow Coolant hose + PRL intercooler 1784492078055-p5
marcusm86
Marcus
Missouri
2025 Civic Type-R
Have you looked into any of the turbo coolers like this airtec? losing the intercooler seems like a tough choice to me.
0x1d7
Washington
2025 Civic Type-R
Acuity hoses are incompatible with the PWR radiator? Damn :-(
So, I got some NIB Acuity hoses...
