Cutaway of the mysterious intake box
Whitboy82
Kris
Dallas
2020 Explorer ST
We’ve posted some pictures, with a straight through view, and there doesn’t appear to be really much of anything inside.
hhkb
hhkb
civic
So it's all a red herring!
Toprarnen
IS350
I always figured it was an intake cover due to the repositioned hood scoop, for liquid/debris protection
FL5ogger
Laser
I think this can be the only explanation. Protecting the turbo from dripping water coming from the bonnet vent.
The plastic would be less likely to corrode over time also.
randomFL5guy
CA
Subaru
Probably just a shield to protect from dripping water. Cold water on hot metal can cause it to crack, so maybe they're just using a little plastic piece to insulate the metal.
citrus
Would it have been much worse to mount a "drip pan" under the scoop on the hood? A la MR2 Spyder, etc.
Toprarnen
IS350
You can't make that look like a pretty engine accessory while the hood is open ?
hhkb
hhkb
civic
I wonder if that area can house some dry ice...
chopsuey34
West Michigan
2025 Civic Si
The MR2 Spyder drip pan under the hood vent is really heavy. It makes the Spdyer trunk as heavy as a normal hood despite it being half the size. Using plastic mounted to the intake tubing is the lighter option compared to a metal pan attached to the hood.
citrus
The pan could be plastic or something. Everything on the Spyder is steel anyway.
hhkb
hhkb
civic
According to Spoon...
11th Gen Honda Civic Cutaway of the mysterious intake box Screen Shot 2022-09-30 at 10.11.52 AM
