Eibach Pro Kit and/or Sportline Experiences
So_si
Silver spring, Md
24 sonic gray FL5
Thank you appreciate it!
No rubbing whatsoever, car loaded and even under heady braking and turn in (confirmed at the last AutoX event lol)
Has been a great mod and honestly don't think it makes sense to go with the Prokit given the minimal margin between the two.
Also do you know if they cut the bump stop?
Loulerg
Lou
2023 Civic Type R BB #5515
CaryH
Cary
Your car looks great with the 1” drop. How has it affected drivability? I would love to lower the car slightly + install a front splitter, but I do scrape on certain angles at stock height even. Any issues thus far?
No not yet,...
CTR
strixauto.com
2023 Civic Type R, 2020 GX460
First ride this year in the CTR. Have one side picture with the Pro-Kit. I’m assuming it’s fully settled, but it has only been driven 20kms. I will give it some more time.
Looks great! It looks fairly low. Sportline would be even lower!
FL5CW
FL5CW
North America
That’s exactly my thoughts as well. I haven’t driven it very much and still needs an alignment. But I’m happy with how it looks aesthetically. I had a real hard time deciding between the Pro-Kit and Sportline springs. I don’t think you can go wrong with either, but am very satisfied with my choice.
Pro-Kit rides a little softer overall, with Sportline having higher spring rates. This is what I would probably base my decision on. The 0.2 inches between the spring sets likely won’t make a very noticeable difference.
  • Like
Reactions: CTR
Nothing
2023 CW FL5 #5044
That's amazing. Over 1" drop -15mm spacers and still doesn't rub under autoX lean. Are you running a lot of camber in the front?
Loulerg
Lou
The car was aligned with factory specs after the springs were installed
mbaapk
Twin Cities
Pacifica
Im running Eibach sportline, car rides like stock, turn is is significantly sharper. No rubbing whatsoever, running 15mm spacers in this setup.
How does the ride feel now a couple months later, any issues with drop or spacers?
FL5CW
FL5CW
North America
What is everyone seeing for rear camber specs with an Eibach drop, without adjustable camber arms?
Loulerg
Lou
Nope! Has been great, only thing I would say is that with this setup, throwing a lip on would be a bit of a gamble lol. Aside from that, no issues, couple of autocross days and no issues.
mbaapk
Twin Cities
Pacifica
Awesome, thanks!!
Litoman
I’m digging this look so much. Have you measured the drop on the sportlines? Is it leveled or the fronts are lower than the rears? Thanks
Loulerg
Lou
I haven't personally measured the "true" drop but based on the specs for the springs, 1.2" F and 0.9"R, it does create a positive rake, which i like personally.
The fitment does look great, note, I am on 15mm spacers.
