Fender vent mesh?
HONDANB
JOHN DOE
FL
NEEDED
Thanks for sharing all of this!!! Just got it done as of now. That should help a little with rock chips when spacers push the wheels out.
11th Gen Honda Civic Fender vent mesh? 20230422_105216
11th Gen Honda Civic Fender vent mesh? 20230422_105411
2023 CTR #3177
Not sure how you guys are sliding it in far enough to be screwed through without pulling the push pins?
I bought a push pin plier and promptly blew one of them up - those things aren't right man. I'll assume I can use a generic replacement but if anyone has a "known good" I won't say know to that info.
HONDANB
JOHN DOE
FL
NEEDED
Mine blew right by me like a stray bullet. Have a look at them. When they blew by me I thought they broken. Upon further inspection they were not. Placed them back with no issues. If broken find an exact replacement at any AutoZone.
2023 CTR #3177
Nah, broke into a million pieces. I live 3 houses down from an AutoZone but it takes forever to buy anything - I honestly just Amazon it.
So close…yet, so far away.?
I get it, though. Like 3 guys working in the back, but 1 guy at the register helping a customer for 30 mins.
2023 CTR #3177
I've got guards on order too.
The pins appear to be 8mm diameter, 10mm long. Turns out a flathead works better than the pliers. Going to order some replacements or stop next door, these are pretty much single use.
midway1
KY
Awesome mod. I just did this and took about an hour for both sides. You really want to remove the bottom clip instead of trying to finagle the mesh in there. Some of the fender is hidden under the lining. The mesh has sharp edges and you wouldn't want to scratch the fender trying to get this thing in there.
mbaapk
Twin Cities
Pacifica
Let us know which you ordered and if they work!
2023 CTR #3177
Let's see some shots from farther away & the other side.
2023 CTR #3177
They should be 8mm, I have been doing pretty poorly at ordering the right things recently so I ended up running to an Autozone a few houses down from me and bought "Dorman 961-37D Honda Splash Shield Push Rivets". The wrong ones I ordered were 10mm.
UJX
Missouri
2023 Honda Civic Type-R #2479
Those that have done this, did you remove the front wheels or is there enough room without having to remove them?
