FL5 PRL HVI Intake Installed
Did anyone else have a problem with the small metal bracket that attaches to the snorkel not set at the right angle so you can reattach the existing connector plug? See the circled part in my photo. They’re about 45 degrees apart and the wiring harness doesn’t have enough flexibility to pivot to the brackets angle unless I cut the stock zip ties to give it more slack.
I think I just unclipped a couple of the wire tie mounts around it to allow the harness some movement.
Moonshine
Jesse
WV
2024 Honda Civic type R
Does anyone know if the cone can be easily removed when it comes time to clean or replace?
Or do you have to partially disassemble the box?
whtciv2k
raf
VA
Integra Type S
Box has to come out.
