FL5 recall (2022-2025 Civic Steering Gearbox Assembly)
latole
Vaudreuil,Quebec ,Canada
What are you on about?
Are you saying that discount tire committed fraud by messing up my alignment and then trying to say that it was off? That’s pretty wild considering I watched them do the whole thing through the window. Also, it’s not the first time that cars don’t have the right toe Settings from the factory to begin. with.
No, I dont say that.
I'm sorry if I misunderstood or misread you
LoggedR
Rochester NY
2024 Boost Blue FL5 type R
What about the cars with ridged collars and race alignments. How is that handled at your shop ?
Haven’t had one yet but id assume if theyre one time use your kinda SOL. And depending on what kind of machine your dealer has the alignment should be no issue. We deal with cambered cars all the time. Only should need to adjust toe after the recall
BigBird
They are not one time use. they usually sit inside of the space of the subframe, so it could fall out when the subframe is moved
BigBird
Depending on how much torque was applied, they “crush” to fill the gap. If they come out when subframe is removed, you likely won’t get them back in if they were crushed/deformed. So technically they are one time use.
interesting. wonder if the spoon ones are the same? The ones I used on my VW were not like this, so they could have been reused.
Bobbymcbobby
Daniel
Hillsboro, Oregon
instagram.com
2023 Honda Civic Type R Championship White
bonslay
Bon
FL5 R
Sorry on the late update, was enjoying the car and forgot lol ?. Picked up the car on tuesday, i requested for alignment sheet which they did provide, car drives straight and drove home in silence to hear for any loose bolts or whatever and seems totally fine! But if i did have a choice Id probably wait a month or so as many cars are going/coming in for this recall, we have to drop off my gfs new hrv for same thing
evlsmurf
2016 Subaru Impreza Sport
I spoke with the Parts Department at my local dealer. They said they are hearing the recall will be updated so the subframe does not need to be dropped. There will be a part available to allow the recall to be completed without having to do such.
Nice. They will gonna have to remove the fender line and will probably fuck up my carbon screen/mudflaps which was kinda a pain to install. Might have to remove before I go get it done but this is much much better
evlsmurf
I'm worried about the removal of my aftermarket wheels and lugs. Unfortunately, I may need to put my stocks back on before doing this.
latole
It is a good news , thank to share
Chance they have do it MooMoo:
11th Gen Honda Civic FL5 recall (2022-2025 Civic Steering Gearbox Assembly) Capture d’écran, le 2024-10-19 à 06.54.38
