machimself
Michael
Okay, I figured it out - the trick is to ignition on in-between.
So, car is off, valve is closed:
1. Pull fuse, ignition on, ignition off.
2. Replace fuse with the car off, valve should open. Then you can pull the fuse again and you're all set.
I drove for a while with the valve unplugged, that's why when I plugged it back in, it immediately opened. This way you don't have to get under the car and can just do everything in the fuse box.
Just to be clear, for this to work you end up with the fuse out entirely right? I got it to the open stage, now I just pull the fuse and it stays open for-ev-ver?
Edit: this is what I did and it seems good to go, just want to make sure I keep the fuse out.
Edit 2: I should have planned this before I knew I could go driving. I'm probably way more excited about this than I should be!
Village911
FL5 #839
I did it this morning and took me about 2 minutes.
Now the sound of the exhaust is perfect to my taste and does not need any aftermarket exhaust system! (who needs tomei :nixon:)
Here is my current setting after fusebox work:
11th Gen Honda Civic FL5 stock exhaust valve: Fuse pulled/always open - exterior sound clips 20230406_123637
Love my car 10X more... Thanks, @TheTopher !!
Endlesspearl
Nova
Great tip. Thanks TheTopher
keep doing what you are doing!
@TheTopher What are the steps to return to stock exhaust valve function?
CTR
strixauto.com
2023 Civic Type R, 2020 GX460
Pretty sure you can just put the fuse back in and power cycle the car. If it's a fused circuit it's designed to lose power and when power returns it should function like normal.
Theoretically that makes sense; however, the initial opening of the valve wasn't as simple as just pulling the fuse. There was a sequence of steps in order to keep the valve open.
@TheTopher , or anyone else, have you gone back to stock exhaust valve operation? If so, can you confirm the order of operations? Thanks.
TheTopher
TheTopher
www.youtube.com
Yep, just plug it back in and all will be back to normal.
Bsnyder6
Virginia
2023 Civic Type R, 2005 Wrangler
Sure glad this worked I somehow managed to drop the fuse into the engine bay...twice. Lord knows where they landed
CTR
strixauto.com
I put my fuse back in last night. I've noticed a few quirks during cold start driving that could be attributed to the valve being open. There has to be a reason Honda kept the valve closed at low RPM in +R mode since even with it open it's not that loud. On cold starts all of the exhaust is coming out of the center pipe which could change the flow and the car is trying to compensate.
This is all a theory and I'll report back after some more driving.
Bsnyder6
Virginia
What quirks have you noticed?
TheTopher
TheTopher
www.youtube.com
I've noticed some rougher cold start behavior too for the first few minutes of driving, but from the beginning of ownership (well before pulling the valve fuse). The open valve is so far back in the exhaust system I doubt it affects flow, just enhances what may have been happening already.
Bsnyder6
Virginia
Makes sense. Think there might be just a hair more vibration but felt about the same as when waking the car up in the dead of winter.
