FX3D rock guards
Yorkman1
Yorkman1
DM
2024 Type-R #170001
That looks pretty nice! Certainly, much better than any of the red mudflaps I often see tacked to 10th Gen Si's (why, guys, why?).
When you get a chance to drive in some sludgey wet winter weather, can you share your thoughts on how clean they help to keep the rear of the vent/front of the door region?
That area seems to be a magnet for filth with my FL5, even in seemingly clear weather.
I don’t drive in the rain if possible. Could take me a long time to get caught ……. It’s a weekend toy ?
Yorkman1
Yorkman1
DM
2024 Type-R #170001
Had some more time to work on it today. The rears are really easy and I like the amount of protection you can give yourself.
11th Gen Honda Civic FX3D rock guards IMG_7360
11th Gen Honda Civic FX3D rock guards IMG_7359
11th Gen Honda Civic FX3D rock guards IMG_7358
KhaoS2K
S2000, FL5R
Hehe nice! You went full protection mode ;)
I mean, the adjustment is mostly useful in the front if you run wider tires or lower offset wheels. In the rear, you basically just need to cover the bumper inner lip, but it's nice to be able to decide how much they poke out and fit the look you prefer.
Yorkman1
Yorkman1
DM
2024 Type-R #170001
I noticed on other cars that I had that had spats/guards when you’re turning you would still get some kickback. So so kept em out a little ways
RUNN1N
Ugh ok fine, I’ve seen enough. I ordered a set. Make sure they send you your commission. ?
Anthonyfa18
Anthony Mark
Laval Quebec Canada
Honda’s
question, is there a way to install the rear mudguards without drilling the extra hole?
From what I see in the installation instructions, they're just using a drill with a screwdriver bit, not actually drilling a hole.
Yorkman1
Yorkman1
DM
2024 Type-R #170001
Yeah it’s just screwing a screw into the lower fender liner
Anthonyfa18
Anthony Mark
Laval Quebec Canada
Honda’s
so it use a existing factory whole, I just got them in the mail I will probably do the installation later this week
Yorkman1
Yorkman1
DM
2024 Type-R #170001
top 2 yes. Bottom uses the spacer and the screw and goes into the composite liner
Anthonyfa18
Anthony Mark
Laval Quebec Canada
Honda’s
If you do not want to make a hole in the composite liner do u think a pice if vhb hold it ?
Snmtazz70
Type R
They use factory lining screws and one drilled into wheel liner.
So which is it? Are you drilling a net new hole or not to install this product?
Yorkman1
Yorkman1
DM
2024 Type-R #170001
i dont think it would, the lower hole has a spacer that is used as an adaptor. the screw is so small no one could even realize you put a hole there.
