nickusa52
nick
Georgia
2023 FL5 Type R
I wanted to start a thread specifically for people running or wanting to run the god spec set up to consolidate information. Post your pictures, alignment specs, tire info(size and model for sidewall profile comparison) etc. To start it off I've got my set of god spec CE28N+ coming in today, looking at running a 275 but am unsure what tires will give me a good proper flush fitment since I've seen that some tires sit wider than others at the same size. Any info or recommendations are greatly appreciated
princers
Z
25 Type R
what suspension are you on? have you pulled the pins? etc.
hhkb
civic
All of our customers run 275/35 on 18x10 +40. All ranging between different suspension setups.
Wow thank you for these photos. Great job on the setups.
any issues with rubbing on any of those setups you’ve seen?
lmtlsauto
LMTLS Auto
shop.lmtlsauto.com
no rubbing on any of these setups. 275s fit like a glove with a lowered suspension setup.
Nothing
2023 CW FL5 #5044
Looks great. I've always wondered, are really high spring rates required to prevent contact under hard cornering, or even turning onto driveways/uneven elevation? For the latter, slower is usually the need and I suppose the front lip is usually the limiting factor.
I recall caster adjustment may have been mentioned to help with this, and rubbing becomes less a problem while turning?
citrus
How well do god spec wheels fit on stock suspension?
citrus
I have 275/35 Advan 601s on god spec and no rubbing at all. Little bit of poke on the front but that is being fixed with a camber adjustment next week.
Thank you! How much camber are you going to run?
