Backmarker
- First Name
- Phillip
- Joined
- May 16, 2023
- Threads
- 4
- Messages
- 14
- Reaction score
- 51
- Location
- Richmond, Va
- Vehicle(s)
- 2023 FL5
- Thread starter
- #1
Hi folks,
Just FYI I will be sharing the results of dyno testing of some of the top “off the shelf” tunes on a bone stock 2023 FL5 running on 93 octane pump gas. I will also be sharing my impressions from daily driving with the Different tunes.
In this comparison, I will be testing:
- Factory base map
- Hondata 93 Octane Basemap
- Phearable Stage 2 tune
- Two Step Performance Stage 1 tune
Without giving too much away, I have already run this head to head test once in December only to have both the Two Step and Phearable tunes pull some timing out above 6100 rpm. After talking with the tuners, it looks like a potential gas quality issue (running 93 octane but possibly a bad batch) For the benefit of adding to the knowledgebase here, I am planning on returning to the dyno to rerun the tests with different / better gas and see what the results on the end up being. Results below 6100 rpm looked good on all four tunes (no knock detected, no timing pulled).
Just so folks don’t wonder around potential bias. I have paid out of pocket for the tunes - which were purchased direct from vendors the same as any one would. I am also paying for the dyno time, etc. out of pocket. Nor do I have any sort of side hustle or anything with this. I make my living in banking... i just spend it here . but I really appreciate this community and the folks who take the time to share learnings and insights. And so I am doing this to give a little back with the community.
Timing wise - I look to get the results up sometime later in January after the holidays. More to come.
- Phillip
- Factory base map
- Phillip
