[Install Guide] Installing aFK8 spare tire and full kit in the FL5
What's the final price on Honda Parts Now after shipping? I know you can pick it up at some dealers with DreamShop so you can avoid shipping charges. I don't think I would care whether it's black or yellow as it's only a spare that'll get me to limp home.
color makes no difference indeed. but weight does...
It seems (I might be wrong) that the yellow is aluminum, and black is steel.
and further, I assume aluminum is lighter weight.
shipping is a killer, but local SoCal stealerships, either direct, or via dreamshop want full $213 price (which is cheaper than $150 plus shipping...)
PNEUMA
Jerry
PNW
2025 FL5
I ordered the same kit 06421-TGH-A33ZA from my dealership back in April, and the wheel included was the yellow aluminum one. The donut spare tire was a separate part number. The dealership mounted it too, and was ready to go when I picked it up. All in was right about $329
caballero_x
Daniel
2025 Honda Civic Type R
weird, that's not what I am seeing at Honda Parts Now, though the price is the same as in your image.
I will contact local SoCal stealerships will not match prices, and some want more than suggested prices...
Just received the tire today can confirm it is the yellow spare
caballero_x
Daniel
Just received the tire today can confirm it is the yellow in
good price they charged 369 for parts and didnt mount it i would need to make an appt with them to do so. Drove down the street to a tire shop and got it mounted for 35$ in 20 min
MR_O’s_DE5
SHANE
Colorado
2008 acura tl type s and a 2024 ITS
Anyone know if you could retro fit this into a de5?
frenzal
Dan
2024 Integra Type S, 2025 TLX type S, 2004 S2000
Look at the threads on the Integra forums. Problem is that the DE5 don't have the fixation point in the trunk. I did manage to add one, but it is involving. Someone else did drill their trunk to add one... Then for the spare, I used a RL spare (17"), but it only fits in the rear. At least it is better than no spare at all. Someone else fitted a BMW wheel, but you have to drill the wheel so it fits on the car.
In short, no easy way.
hakkago
Kent
2024 Civic type R, 2005 Miata, 2004 Volvo V70R
The foam posts you removed do serve a purpose if one wants to use the factory foam tray: they contact the spare around the tray and add support to the floor. Doing this does make the whole thing another inch or so higher, and will need a solution to support the back lateral edges of the floor by the same amount. It DOES add a broad support base to the center of the floor for ppl who carry heavy stuff (I do.)
BLU RRR
Jeff
South Central PA
06421-TGH-A13ZA also works for the spare tire kit. Dealer couldnt find 33ZA or 23ZA so maybe 13ZA is an updated number? Continental tire is (T124-70-18) 42751-CTL-039
Total was $363.75 + $21.83 tax = 385.58.
11th Gen Honda Civic [Install Guide] Installing aFK8 spare tire and full kit in the FL5 IMG_4608
11th Gen Honda Civic [Install Guide] Installing aFK8 spare tire and full kit in the FL5 IMG_4609
11th Gen Honda Civic [Install Guide] Installing aFK8 spare tire and full kit in the FL5 IMG_4610
artsyfartsyFL5
Ant
PA
www.instagram.com
2025 CW FL5
Im a little confused on this, (maybe having a blonde moment). Since this is for thre FK8 which came with 20" OEM wheels, how does this work with the FL5 19in OEM wheels?
Xmetal
CTR, S3
If the spare clear the calipers/rotors on the 20" OEM, it will work on the FL5 19" setup. The overall diameter of both are similar (FK8 have less tire sidewall). Bolt pattern and hub are the same.
BLU RRR
Jeff
South Central PA
The overall circumference of the wheel with tire for the FK8 and FL5 is about the same so the spare fits for both. actually the spare is closer to the FL5 than the FK8.
FK8 245/30/20: 81"
FL5 265/30/19: 79.4"
spare 125/70/18: 78.2"
artsyfartsyFL5
Ant
PA
www.instagram.com
2025 CW FL5
FK8 245/30/20: 81"
Awesome, thanks for the info! Been thinking about doing this so this helps.
cullystout
James
San Antonio, TX
2026 Civic Type R
Just wanted to add my own experience. Purchased the FK8 spare wheel kit (part #06421-TGH-A33ZA) and tire (part #42751-CTL-039) and picked it up at a local dealership after having the service dept. mount the tire to the wheel rim. Kit, $214; tire, $150; mounting fee, $27; shipping, none; total = $391 + tax. It is also worth calling around to more than one dealership, I'm not saying I got the best price, but the second dealership I called quoted a price of nearly $200 more.
Install: I am actually super happy with simply removing the FL5 foam insert kit from the wheel well, replacing with the FK8 spare wheel and tire, securing it to the pre-existing central bolt rececpticle with the included fastening bolt, and re-laying the original FL5 over the top for a flat and stable surface, which is slightly lower than the hatch latch level, provides side storage cubbies, and also does not interfere with the subwoofer! Also, there is ample space inside the spare wheel to store the jack and associated tools, along with peripherals such as tire inflater and battery jumper units.
So, I am not planning on using the included FK8 trunk cover, FK8 foam wheel insert with tool slots, nor the original FL5 foam insert kit. I guess these are on sale for cheap if anyone is interested!
Finally, I've gone down a bit of a rabbit hole on this whole topic. I know for many improvised spare tire setups, only the rears can be replaced with a spare due to brake caliper clearance issues in the front and then a second tire movement would be needed if the flat is on a front tire. Anyway, I can't remember, can my OEM FK8 spare be used on the back and front or only back?
Cheers everyone
11th Gen Honda Civic [Install Guide] Installing aFK8 spare tire and full kit in the FL5 floor befor
11th Gen Honda Civic [Install Guide] Installing aFK8 spare tire and full kit in the FL5 wheel well befor
11th Gen Honda Civic [Install Guide] Installing aFK8 spare tire and full kit in the FL5 wheel well after
11th Gen Honda Civic [Install Guide] Installing aFK8 spare tire and full kit in the FL5 floor after
cullystout
James
San Antonio, TX
2026 Civic Type R
update a day later.
- hhkb, I followed your advice for adding the spare tire info over the existing tire spec sticker. So easy, yet I don't think I would have come up with that, instead I was thinking along the lines of adding the sticker to the passenger side, which would have been very confusing!
- The spare tire kit also comes with three rectangular rubber adhesive patches that I was at a loss as to how to utilize. Kudos to reddit user DamnedlflDO for clarifying. Essentially, there are three raised metal areas, one forward and two to the sides...I was going to put a link, but it seems to be beyond my tech knowledge; instead, google 'civic type r spare tire' and go the reddit thread, if interested (but, I am also enclosing a pic showing the three contact areas)
- Also, I've already put my side storage "cubbies" to good use by transporting my dirty work boots
11th Gen Honda Civic [Install Guide] Installing aFK8 spare tire and full kit in the FL5 Screen Shot 2026-07-01 at 15.10.59
11th Gen Honda Civic [Install Guide] Installing aFK8 spare tire and full kit in the FL5 IMG_3935
Xmetal
CTR, S3
I saw this picture posted on reddit. Anyone know the part number for the foam surround? Thanks.
11th Gen Honda Civic [Install Guide] Installing aFK8 spare tire and full kit in the FL5 1782962982306-sc
