Installed Sunglass Holder in US 2022 Civic Si
RUNN1N
@ThunderPigeon I've confirmed the FL5 does not have a mounting structure, and also the roof liner curves up with little room, hence the measurements would help a ton. If the length works out, I'm willing to give it a go.
Did you end up giving this a try? I'm tempted as well, but I'd look to do it while installing a Homelink mirror.
sashimi
CW FL5
it won’t fit flush like it does in the Si. The FL5 headliner is different.
nate1015
Civic EX 2024
Looking to do this in my 2024 EX Civic while I'm swapping out the rear view mirror. Looks like the mounting structure is present and matches what I'm seeing in the SI pictures from the original post.
Anyone see anything different in the mounting structure on the EX based on my photos? Reading above it wasn't compatible for the sport and just wanted to get a second opinon in this before I start cutting.
Thanks!
11th Gen Honda Civic Installed Sunglass Holder in US 2022 Civic Si IMG_4702
11th Gen Honda Civic Installed Sunglass Holder in US 2022 Civic Si IMG_4701
Bald Wonder
Jason
Cleveland, OH
2024 Honda Civic Si
I just did this last night, along with the mirror swap. It went very easily. In case anyone needs a tip on how to make a template, below are pictures from my template creation; I put masking tape down on the flanges, taped it to a sheet of cardboard, then slipped out (pulled very hard) the new unit.
One bit of advice: if you don't cut the hole long enough, the headliner will push against the plastic and the sunglass holder will rub on the shell. You'll know it's too tight if the holes for the screws don't line up centered in the mounting area.
11th Gen Honda Civic Installed Sunglass Holder in US 2022 Civic Si PXL_20250423_005626286
11th Gen Honda Civic Installed Sunglass Holder in US 2022 Civic Si PXL_20250423_005933668
11th Gen Honda Civic Installed Sunglass Holder in US 2022 Civic Si PXL_20250423_010342861
11th Gen Honda Civic Installed Sunglass Holder in US 2022 Civic Si PXL_20250423_010358513.MP~2
11th Gen Honda Civic Installed Sunglass Holder in US 2022 Civic Si PXL_20250423_011522090.MP
11th Gen Honda Civic Installed Sunglass Holder in US 2022 Civic Si PXL_20250423_011618197
mickjaggaj
Nick
Portland, OR
2026 Civic Si
How did you get all the lights, etc out of the housing so you could transfer them to the new part?
ThunderPigeon
ThunderPigeon
Long Island
I didn't need to swap them since I grabbed the whole assembly from a wrecked Integra. But from other parts I have taken apart, there are probably screws and clips holding them on in the back.
mickjaggaj
Nick
Portland, OR
2026 Civic Si
There absolutely are but for the life of me I can't get anything out of the assembly. Wahhhhhhh.
