Jacking From Pinch Points
Spart
2025 Integra Type S
I have ramps and still need a pair of 2 x 12 to get onto the ramps with to avoid damage to the front bumper and I'm not lowered. Even have larger than OEM diameter tires.
I just jack my car up to put it on ramps. Same situation. I just use the ramps backwards since the jack ends up being where the sloped part of the ramp would be otherwise.
floggindave
2007 Ridgeline
got it! thanks! will purchase a ramps.
I made my own for less than 20 bucks. Picked up a damaged 2x10 from the lumber yard and had them cut it. 2 3ft pieces and 2 2ft pieces, which i screwed together. Worked a treat
mbraun
canada
I worked through this problem last summer, and ended up with some reasonably priced longer ramps that work perfectly. I bought mine in Canada, but see similar ones (probably all from same Chinese factory) online in the USA. You can see my oil change video at
I show the ramps just after the 2 min mark.
SuperDave
Dave
Los Angeles
2017 Civic Si - aegean blue
I use a small jack (2 ton) to slightly jack up one side from front pinch weld. Then use my 3 ton jack to raise from the front center jack point (deep under the front end).
Then I use two jack stands under the front pinch welds.
I also put a jack or two behind the jack stands, that is just barely touching the actual pinch weld which is covered by the rocker molding.
11th Gen Honda Civic Jacking From Pinch Points 20260122_145704
