J's Racing Hyper Intercooler
hoping2Get1
Maryland
'24 CW CTR
This is before customs fee
Try checking shipping cost/options couple times a day for a few days. At least for me that’s how I got the cheaper option (UPS) as @blueroadster mentioned. FWIW, UPS did email me when my items cleared customs, paid $65 for a set of wheels.
Tougefl5
Appreciate the information.
Custom fees is not consistently charged, even if it’s the same carrier. I’ve bought from BHJ a few times now and it’s not consistent.
Agree. I've never once paid custom import fees and I've spent around $10k all told.
Times are changing. A friend of mine very recently bought something expensive from Canada (~$3k item). It was held up in customs for a few days, then almost made its way to his home in California, but then got rerouted back to one of the main FedEx hubs (Memphis) for customs processing. What a mess!
HKS Intercooler Pipe Kit arrived. There was no customs fee charged I guess because the box is not large or heavy. Let me know if there are an questions about measurements or something else before I install the kit.
11th Gen Honda Civic J's Racing Hyper Intercooler 1744822155815-y1
11th Gen Honda Civic J's Racing Hyper Intercooler 1744822176471-ze
FYSA for those curious. Here is a PIC of the OEM intercooler port where the shape is elliptical (internal port measurements are 59.75mm height x 55.5mm width (same on both sides)):
11th Gen Honda Civic J's Racing Hyper Intercooler 1744833050487-uk
The HKS and J's Racing Intercoolers maintain the same elliptical shape (PICs from video in first post):
11th Gen Honda Civic J's Racing Hyper Intercooler 1744833828646-u9
11th Gen Honda Civic J's Racing Hyper Intercooler 1744833755053-d5
As for the HKS Intercooler Piping Kit, the ports on the cast aluminum elbow connections are also elliptical on the ends connecting to the intercooler. The hot side internal port measurement was 60.00mm height x 55.75mm width. The cold side internal port measurement was slightly smaller measuring 58.35mm height x 52.5mm width:
11th Gen Honda Civic J's Racing Hyper Intercooler 1744834221982-io
The other sides of the cast aluminum elbow connections both have an internal circular diameter of 54.00mm:
11th Gen Honda Civic J's Racing Hyper Intercooler 1744834964762-bd
As for the HKS Intercooler Piping Kit, the ports on the cast aluminum elbow connections are also elliptical on the ends connecting to the intercooler The hot side internal port measurement was 60.00mm height x 55.75mm width. The cold side internal port measurement was slightly smaller measuring 58.35mm height x 52.5mm width (I read somewhere that the OEM plastic elbow on the cold side is smaller but will need to measure later) :
The other sides of the cast aluminum output connections both have an internal circular diameter of 54.00mm:
Just want to say that I appreciate your deep dives into all the parts you’re installing. One can’t have too much info.
Thanks and NP…Just sharing information as a means to help others in their decision process.
Overall, I think the HKS Intercooler and charge pipe kit is a sweet deal. The HKS Intercooler by itself is a significant improvement over OEM. Adding the HKS charge pipe kit makes it even better by replacing OEM hoses with hard pipes.
Core design wise…I think the J’s Racing Intercooler is better than the HKS. Likely not worth the additional cost though.
After installing the HKS intercooler piping kit, I am impressed. Internal dimensions of the piping from turbo outlet to the throttle body inlet pipe are larger than stock on both the hot and cold sides.
OEM turbo outlet: 50mm ID, OD connects to a 55mm ID rubber hose connection
OEM intercooler inlet elbow (cast aluminum): 50mm ID, OD connects to a 55mm ID rubber hose connection from the turbo outlet
OEM intercooler outlet elbow (resin): 53mm ID, OD connects to a 60mm ID rubber hose connection to the throttle body inlet pipe
OEM turbo outlet: 50mm ID (HKS provides a 55mm to 60mm silicone adaptor)
HKS intercooler inlet elbow (cast aluminum): 54mm ID, OD connects to a 60mm ID silicon fitting
HKS intercooler outlet elbow (cast aluminum): 54mm ID, OD connects to a 60mm ID silicon fitting
HKS intercooler piping: Mandrel bent aluminum with a 54mm ID, OD connects to 60mm ID silicon fittings on the hot and cold sides
Considering minimum intercooler piping inlet and outlet diameters, OEM maintains a 50mm ID (1.968") on the hot side and a 53mm ID (2.086") on the cold side. HKS maintains a 54mm ID (2.126") on the hot side post turbo outlet (16.63% larger internal circular area) and the same 54mm ID (2.126") on the cold side (3.81% larger internal circular area).
When installing the HKS intercooler piping kit, everything fits like a glove however, minor trimming of the passenger's side brake duct bracket is needed to fit the larger intercooler inlet elbow (cast aluminum). Here are before and after PICs of the bracket showing the required trim area:
11th Gen Honda Civic J's Racing Hyper Intercooler 1745539358692-t2
11th Gen Honda Civic J's Racing Hyper Intercooler 1745539390960-0r
You can use a file or angle grinder to trim. Once trimmed, you can spray some black epoxy paint onto a paper plate and use a Q-tip to dab and apply paint without having to spray. Here is a PIC of the passenger's side brake duct bracket before removing to trim:
11th Gen Honda Civic J's Racing Hyper Intercooler 1745539597325-61
Same PIC after trimming, painting and reinstalling:
11th Gen Honda Civic J's Racing Hyper Intercooler 1745539636853-5
This PIC shows clearance after installing the HKS intercooler inlet elbow:
11th Gen Honda Civic J's Racing Hyper Intercooler 1745539876608-1n
Other random post install PICs:
11th Gen Honda Civic J's Racing Hyper Intercooler 1745540099046-3l
11th Gen Honda Civic J's Racing Hyper Intercooler 1745540120038-3o
11th Gen Honda Civic J's Racing Hyper Intercooler 1745540177927-o5
11th Gen Honda Civic J's Racing Hyper Intercooler 1745540197099-05
Thanks for the writeup! Are you seeing any significant difference in IAT's?
Sorry I missed this question...Yes, I have noticed a significant difference in drops to IAT's when the engine is under load. Much faster IAT drops as compared to the OEM intercooler. When the OEM intercooler heat soaked, it seemed to struggle trying to recover. The J's Racing intercooler has yet to heat soak and is doing a great job shedding heat under load as one would expect for an intercooler to do.
Thank you for the feedback. That will be my next mod I think. So far the stock intercooler has seemed sufficient this last few weeks I’ve been driving the car, but it has been very cool up in New England. I know once the summer arrives in earnest, that won’t be the case. In the meantime, I’m data logging a lot of my driving so I have temperature data to compare. I’ll be interested to see how the IATs effect boost and timing when it gets warmer, and any differences after installing a more efficient intercooler.
2+ month update and I am still really digging the J's Racing Hyper intercooler. I also appreciate the fact that the fins on the front are folded over and do not deform when big bugs collide.
Knowing what I know today, I would still order the same intercooler with the HKS charge pipes. On the other hand, the HKS intercooler "kit" is a solid choice that would save quite a few Benjamin's. Both intercoolers are a great upgrade since they are efficient and increase airflow to the radiator to help lower coolant temps.
It is however important to consider expected results when upgrading components. If you are seeing coolant and IAT temps rise high in the Summer during stop and go traffic, a better option to consider would be replacing the shielding on the OEM downpipe. If you think about it, the OEM downpipe has a large surface area radiating 600+ degree temps to the back of the radiator and front of the block. In low airflow conditions, that radiation heats/soaks many other parts under the hood. If that is the problem needing to be solved in the Summer, I would recommend considering the PTP Hybrid Downpipe Blanket first and then observe from there. After installing the blanket, I have noticed significant under hood temp reductions in stop and go traffic where radiant heat from the downpipe was reduced by over 400 degrees. Something to chew on and consider.
