Lighter wheel, looks stock, same specs?
Zpeedster M
New York
2023 Type R FL5
Lighter wheels & rotors will lower the car's unspring weight & can improve its handling, performance, and durability. Upgrading rotors mainly for dissipating more heat providing consistent and powerful braking under heavy use,
jcfishel
Cary, NC
2025 Honda Civic Type R #35339
Its always been my opinion that the Titan7 forged T-S5 looks near identical to the stock FL5 wheels and the 18" version save about 7lbs over stock w/ tires. (Stock = 52lbs., T-S5 = 45lbs.)
11th Gen Honda Civic Lighter wheel, looks stock, same specs? titan T-S5 vs stock FL5
lrk322
lrk322
Type R 2021
Thanks for all of these suggestions. The ts5 and super speed both look great. Ideally would try to stay close to the 19 size and offset, but I understand some compromises need to be made.
BigBird
@TW00Si thanks for sharing. Could you feel a difference in the weight savings? I wonder if it’d be even more noticeable combing it with the lighter girodisc rotors, saving about 8 pounds per corner.
I can definitely can feel a difference when saving about 5-7 lbs of unsprung weight
us17094
Tenny
Accord 2.0T 6 speed
I also have a set of the Superspeed RFO5RR flow formed wheels. Less than half the price of their forged line. Clearly they won't be as light or as cool as the forged wheel but I have been pleased so far - and they look great.
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
Here are the superspeeds on an FL5
Oh hey, that's our new FL5! Haven't had a chance to talk about it much on the forum yet, will introduce it soon
Specs are 18x9.5 +38 Superspeed RF05RR with 255/35R18 Michelin X-ice Snow Tires. Lowered on Swift's, no rubbing. Also swapped over to the DE5 ADS Module
JBO
Jim
Adelaide South Australia
2023 FL5 CTR | 2025 GR Yaris
Nice. Would you run 265 in summer?
Unity Performance
Humza
Will clear 265's with ease, and we've seen others run 275's on the same wheel and suspension setup. Although I'd leave it at 265 as a fully loaded car with passengers and/or luggage may rub.
Briefly we ran the same wheel and spec with 265/40 on our first FL5 (not lowered at the time), which filled up the wheel gap quite well. When we lowered the first car on Spoon Springs we did 18x9.5 +45 with 275/35R18.
11th Gen Honda Civic Lighter wheel, looks stock, same specs? 20230501_222424
11th Gen Honda Civic Lighter wheel, looks stock, same specs? 20230907_105055
lrk322
lrk322
Type R 2021
Thanks all for the ideas!
us17094
Tenny
Accord 2.0T 6 speed
I love this! I want to fill up the wheel wells more but don't want to lower the car. Like my Conti's I use in the winter, it seems like they run a bit narrow and look at little "stretched" at 265. Do you think a 275/40 could work without rubbing?
FK82FL5
CA
24 FL5
I've seen one picture online of someone with NSX wheels on an FL5. They weigh about 7 pounds lighter and are really close in offset at 55. The only catch is they are only a 8.5 wide wheel compared to 9.5 for stock. I've seen some Fk8 owners are still running 265's on them as well. I wonder if these are something worth looking into?
