My first oil change ever!
HorizonsEdge
aaron
Rockland County NY
2025 civic type r
Reading this forum galvanized me to bite the bullet and learn how to do this. I acquired the tools, the floor jack (HF low profile/long reach), some low ramps and built some wheel cribbing out of 2x4 lumber.
Cars first change was done at the dealership @ 4264mi
Second change done today by me @ 7420mi (minder was at 60%, now reset)
HRC 0w-20 oil, factory filter and magnetic drain plug+crush washer
Sample taken for Blackstone will post it when I get results
Some observations for a first timer.
1 - The under tray/shield is really flimsy. I might have to go after market
2 - The force of the oil out of the plug exceeded my anticipation and missed the capture tray initially. Powdered laundry detergent works great at cleaning it up.
3 - Torquing the filter and plug to their specs required more force than I expected.
4 - It is pretty easy to guesstimate the last 0.7 quarts but wouldn't it be great if the containers had more hash marks. Curious what experienced people do?
5 - Serious consideration will be given to acquiring one of the engineered plugs that provide drainage via a hose without removal of the plug itself.
6 - I like that I can document the work via Carfax app (previously utilized for winter tire rotation).
I am now fully invested. In the spring, I will do transmission fluid, oil change, air filter and cabin filter. For a retired software developer this provided some modicum of joy plus a sense of accomplishment.
Any and all feedback is welcome
Savannah@TSP
www.twostepperformance.com
MDR makes an excellent aftermarket skid plate.
I have not personally used this oil funnel, but a buddy of mine does, and likes it a lot.
One of our employees here enjoys their Fumoto valve. Even with the lock, the design doesn't give me the warm and fuzzies, but to each their own. It's your car, and if it helps you, then so be it.
I have ValvoMax on two cars. love it. seems better design than Futomo
https://www.valvomax.com
I also have the WOT HPT Cooling tray. much more sturdy than OEM, and adds bit more cooling/airflow
One of the nice things about this forum is the community, passion, and collective information shared. I am impressed with the stock FL5 but had a concern last Summer seeing various temps rise where it seemed like the FL5 could really use help to shed heat more effectively. I prefer to do upgrades in incremental steps to see if expectations are headed in the right direction before considering other upgrades.
My first step was to find a replacement for the stock intercooler and am awaiting delivery. I then stumbled across this particular post on the forum:
https://www.civicxi.com/forum/threa...ays-and-temp-issues.54189/page-14#post-922617
Take my money from someone that is a forum member, tracks their FL5, understands the heat buildup situation, and is offering solutions. I ordered the cooling plate and it arrived today. I am impressed with it and look forward to installing. Here are two PICs of both sides of the cooling plate after removing the protective film (bottom and then top side view):
Jason is the guy behind WOT Performance and he has an Instagram account (https://www.instagram.com/wot__performance/). Great guy and I look forward to learning about other cooling/performance solutions that he has in store.
I'd be careful if you feel like it took too much effort to torque the filter, taking it off it might feel tighter, but putting it on should take basically no effort. Perhaps you need a more accurate torque wrench? I have two. One for smaller torques, one for those bigger numbers.
That or your hands have gotten too soft at the desk for a few decades 🤣
HorizonsEdge
aaron
Rockland County NY
2025 civic type r
I thought the filter would be effortless but in cramped space with a really short torque wrench using the honda filter socket it exceeded my expectations. I have a wrench that goes 5lb to 30.
I tried several different oil filter wrenches, the one that I fits it tight places is the one with three adjustable jaws and a square hole for a 3/8 (or was it 1/2") wrench handle.
I had to wrap sandpaper around each jaw to provide more grip and eliminate slip.
I do not use it to tighten, only to loosen. I hand tighten the oil filter, then a quarter turn past hand tight using a quarter sheet of sandpaper to improve grip (esp with oily gloves)
similar to these
https://www.amazon.com/Toolwiz-Universal-Adjustable-Removing-Diameters/dp/B0CJTCFJ2H
https://www.amazon.com/Spurtar-Removal-Adjustable-64mm-104mm-Non-Slip/dp/B0FSL4KXYZ
i use a Valvomax quick drain plug and it works well. Solid construction, no leaks, easy to use. There's a bunch of similar ones like Fumoto, Femco, and probably a dozen or more others. No complaints with the Valvomax though.
11th Gen Honda Civic My first oil change ever! 1795502832844-vz
11th Gen Honda Civic My first oil change ever! 1795625443400-mo
for the oil filter, I use an EWK oil filter wrench. 64mm, 14-flute. works perfectly with Honda and all the aftermarket filters I've used including Mobil 1 and Carquest.
HorizonsEdge
aaron
Rockland County NY
2025 civic type r
It appears that i did not screw up. Drove 100 miles. Idle pressure hung out around 20. Highway pressure around 80. I check the oil level later when it cools down a little.
EDIT: wow I so hate the orange dipstick. after checking multiple times at different angles it is just below high. It was so much easier pre change with slightly dirty oil.
Savannah@TSP
Both idle and highway pressures seem normal based on your report.
HorizonsEdge
aaron
Rockland County NY
2025 civic type r
Montrix
Andre
Massachusetts
2025 Type R SGP
I had a Valvomax on my STI, it was only on there for one oil change before I traded in the car but it worked well. Ultimately, removing the filter is still going to cause some amount of mess so I didn't bother with it on the Type R.
My drain pan has an extension doodad that allows me to get it right up against the drain hole which helps with splashing and what not.
I roughened up the shiny orange plastic tip with some sandpaper to help distinguish the now dull plastic from the shiny fresh oil
I also cut two notches with a fine file all around the plastic tip at the same level where the lower and upper level holes are located. it helps me see if oil reached and filled the notches.
I've half thought of buying a bunch of OEM dipsticks, cutting holes and notches in same spots as the plastic and selling them. Seems modifying the OEM stock is a good option imo.
