New Type R (FL5) Owner!
TolgaTypeR
TolgaTypeR
Tolga
TX
South OC, but travel to LA quite a bit.
I hope you don't get stuck in LA traffic or else that left calf cramp starts creeping in real quick LoL
zumbooruk
Ventura CA
QUESTION on tire size, personally think the 265/30 is too low profile, would I be ok with 275/35 considering suspension is stock? Will there be any rubbing on any part of the vehicle?
275/35R19 will fit per several reports here.
I am planning to get this size when OEM tires wear out.
Probably DWS 06+
TolgaTypeR
TolgaTypeR
Tolga
TX
Probably DWS 06+
Damn just looked at prices, the stock tires are like $334/tire
The 275 35 19s are $285/tire.
Are there any other brands that are good. I'm assuming DWS 06+ are pretty solid choice, right?
zumbooruk
Ventura CA
Michelin Pilot Sport All Season but I believe that it is more expensive
Goodyear Eagle F1 All Season won 2026 Tire Rack test about the same price as DWS 06+ but it is new so less long-term owner data
Most other tires offer lower performance at about the same price (or even higher)
Few are cheaper, about $250/tire
TolgaTypeR
TolgaTypeR
Tolga
TX
Good info thank you so much for sharing. Now I know what I'm not looking forward to when the time comes.
TolgaTypeR
TolgaTypeR
Tolga
TX
Found some great condition OEM Red Interior floor mats for $180 shipped.
They look great red on red :drool:
11th Gen Honda Civic New Type R (FL5) Owner! carpet
Evox787
Elvin
I can assure you that the DWS 06+ is a little more quiet than the OE tire. I have the OE size on mine265/30. I didn’t want to be jumping hoops trying to reinvent the wheel. I installed even 19x9.5 +50 on the offset, not +45 like everyone else; I don’t like the way the wheel pokes out. Also, nobody near me installed the reverse mount required on the OEM wheel. I put 600 miles a little bit more weekly on the I35 and the DSW06+ are really good.
TolgaTypeR
TolgaTypeR
Tolga
TX
The stock specs are interesting, such low profile.
  • Wheel Size: 19 x 9.5 inches
  • Wheel Offset: +60 mm
  • Bolt Pattern (PCD): 5x120 mm (center bore: 64.1 mm)
  • Tire Size: 265/30ZR19 93Y (Michelin Pilot Sport 4S)
I like the beefier look, most likely will go with the DWS 06+ 275/35ZR19.
I don't really plan on lowering the car, but who knows lol.
Evox787
Elvin
Yes, I shared your situation until one tire was damaged by the dealer during mounting, as they struggled with the reverse mount. Around 30,000 miles, if I recall correctly, the original alignment is aggressive for everyday driving. You cannot adjust the car much without altering a few components; in my case, I installed PRL rigid collars that set the front alignment to the same specification after lowering it, and I now run –1.7, if memory serves, whereas I previously had –2.2. I recorded all the specifications in my journal, but even at the rear, fixing the setup for less aggression requires adjustable toe arms.
I am at –1.5 and 8 degrees of total toe because the tires would wear out quickly, which is why I chose to lower the car and use different wheels while keeping the original size.
Cueyo
That previous owner must've really taken out a lot. Those also came stock, I keep mine under the trunk weather mat
Also the PS4S was like $260/tire last year 😵‍💫
TolgaTypeR
TolgaTypeR
Tolga
TX
Car came with black mats instead of red. Lol what would be the story there?
Imagine there are red ones there let me go check 😂
TolgaTypeR
TolgaTypeR
Tolga
TX
Thanks for the information, I recall going down this rabbit hole before when I was trying to fit 245s in my civic si while dropped on Teins and I had enkei 17x9 wheels.
TolgaTypeR
TolgaTypeR
Tolga
TX
Hm there are black type R floor mats and they look bigger than the red ones I just received. They look bulkier..
Cueyo
Hm there are black type R floor mats and they look bigger than the red ones I just received. They look bulkier and bigger than the red ones.
Those might be the all weather mats, interesting that you have those and not the OEM red mats lol
TolgaTypeR
TolgaTypeR
Tolga
TX
I found some on eBay, these are the ones I have, it's not all weathe though, it's carpet material.
Floor Mats
