Oil filter question
ellupo11
Dario
Bay Area, CA
2025 Civic Type R in black
Got my black R 2 weeks ago.
Was wondering what oil filter you guys use? In another forum most people say OEM and yet in another one most dislike Hondas OEM filter.
Any opinions on Hengst or Wix?
11th Gen Honda Civic Oil filter question 20251109_150326
ellupo11
Dario
Bay Area, CA
I use OEM, no reason to use some fancy filter if I'm replacing them every oil change
Mainly asking because Hondas seems to let larger particles pass and has less efficiency... assuming the AI response is accurate (micron rating that specifies it filters out at least 70% of particles 30 microns and larger, and 85% of particles 40 microns and larger).
Most other brands have a 20 micron rating. Wondering if these test are done the same way because that's a pretty good difference
Deleted User 3888
The oem filter is trash. To be fair all oem filters suck (canister ones at least)
the better U filter. The worse your flow. The better your flow. The worse U filter.
the Honda hamp filter is superior but at that price there’s a fuck ton of third party filters that are better than the hamp. And way cheaper too. I’d jump on YouTube. Find the filter that has the balance between filtration and flow U gel with most.
I prefer OEM Honda filters:
1. I like the o-ring seal (vs. flat gasket)
2. The flats fit my socket wrench (aftermarket filters vary some)
3. And no risk to the warranty
I've never had a problem with Honda filters. I've had issues with aftermarket filters falling apart inside, leaking past flat gaskets, and drain-back valves not working.
I use WIX XP I remember reading somewhere that it was a bit better
My understanding (see below) is that the Honda OEM oil filter is just a re-labeled lower-end Honeywell-Fram filter.
I use Fram ultra synthetic oil filter (XG7317), which based on my research is one of the best filters out there, 99.7% efficiency @ 20 micron, highest dirt holding capacity, silicone valve. which makes it better than Mobil, Wix, Bosch, Purolator.
and further research seems to indicate that newer next gen Fram FE7317 (which is a Walmart-exclusive) might be even better (spec wise), higher flow, higher bypass valve, more dirt holding.
https://www.fram.com/engine-oil-filter-fe7317
https://www.walmart.com/ip/FRAM-Syn...nt-Oil-Filter-for-Selected-Vehicle/1207345143
https://bobistheoilguy.com/forums/threads/honda-15400-a02-or.369158 "The A02 is a Fram,"
"A02 - made by Fram"
https://www.piloteers.org/threads/oil-filters-oem-v-fram-or-others.152410 "The standard OEM Honda filter (15400-PLM-A02) is made by Honeywell/Fram and appears to be similar to the Fram Tough Guard Filter."
https://www.amazon.com/Genuine-Honda-15400-PLM-A02-Honeywell-Filter/dp/B00BFDFJA2 Amazon product page titles it "Genuine Honda 15400-PLM-A02 Oil (Honeywell) Filter"
https://bobistheoilguy.com/forums/threads/cut-open-honda-15400-plm-a02-fram-virgin.282767/ Detailed teardown thread with photos: "Cut Open Honda 15400-PLM-A02 (Fram)"
chopsuey34
West Michigan
Amsoil is 99% efficient at 20 microns.
M1 is 99% efficient at 30 micros.
Per their websites.
ellupo11
Dario
Bay Area, CA
Per their websites.
If AI is correct and these are the Honda OEM filter specs, that's a significant difference
Filters out at least 70% of particles 30 microns and larger, and 85% of particles 40 microns and larger
Hmm interesting because I've heard from alot of people that FRAM is garbage now. Unfamiliar with Honda but on the Subaru side I basically asked the same question for my BRZ and alot of people were saying FRAM used to be good
Deleted User 3888
The Honda filter’s media is not synthetic like some fram filters. And to my knowledge. The amsoil filter is the best filtering period. However their flow isn’t great. For a daily that gets pushed hard occasionally. You’d want a good balance between flow and filtering. Two things the Honda filter is terrible at
Where does the WIX XP come into play with this?
Deleted User 3888
In terms of its balance between filtration and flow. It’s good. It is not great but it is good
I personally run the wix xp.
regular wix, can’t recommend. It’s better than the stock filter. But not by much.
someone above mentioned AI, so FWIW I asked Grok 4 Expert to research and rate:
Based on ISO 4548-12 lab tests from independent sources like Ascent Filtration Testing and manufacturer data sheets, I ranked the top oil filters compatible with your FL5 Civic Type R's K20C1 engine. These focus on filtration efficiency (higher % better), particle size filtered (lower microns better), dirt holding capacity (higher grams better), oil flow (lower pressure drop or higher GPM better), and bypass valve pressure (balanced to avoid early bypass but protect during spikes). I prioritized filters with validated data over claims, ignoring user opinions or forums. All are direct fits to the OEM 15400-PLM-A02 spec.
Filter ModelFiltration EfficiencyParticle Size FilteredDirt Holding CapacityOil Flow (at ~30 LPM or rated)Bypass Valve Pressure
FRAM Synthetic Endurance FE731799% (ISO 4548-12)>20 microns~25-35 gramsLow restriction (~5 psid drop)11-17 PSI
FRAM Ultra Synthetic XG731799.96% (ISO 4548-12)>20 microns (effective to 10 microns)13.6 grams9-11 GPM (~5.23 psid drop)8-11 PSI
AMSOIL EA15K2098.7% (ISO 4548-12)>20 microns (effective to 15 microns)High (superior to standard)Low restriction12-16 PSI
Bosch Premium 332399% (ISO 4548-12)>20 microns14 gramsGood flow8-11 PSI
Royal Purple 10-286799.08% (ISO 4548-12)>25 microns10.1 grams~8.84 psid drop14-18 PSI
Mobil 1 M1-110A99.6%>25 microns28 gramsHigh flow12-15 PSI
K&N HP-1010High (lab-tested)>10 micronsHighHigh flow rates8-12 PSI
WIX 57356XP61.61% (ISO 4548-12)>21 microns18.1 grams9-11 GPM (~4.98 psid drop)8-11 PSI
Purolator Boss PBL1461061.8% (ISO 4548-12)>30 microns12.5 gramsHigh flow (~6.82 psid drop)14-18 PSI
Mann HU618xHigh (manufacturer)>20 micronsHighLow restriction12-16 PSI
Honda OEM (Honeywell FRAM)98%>25-30 micronsGoodMaximizes flow8-12 PSI
The FRAM FE7317 ranks highest overall for your setup—it excels in efficiency and capacity to trap fines from spirited driving without restricting flow in heat, reducing turbo and bearing wear. Pair with 0W-20 synthetic for best results.
Deleted User 3888
I dunno about all the data but I know for a fact, amsoil filters flow like shit and aren’t preferred in Motorsports due to that. They do filter very well tho
no offense to anyone here. I love their oil but not a fan of their oil filters myself for my car.
I wonder if anything else there was wrong
