Paint Issues
Blackbomber
Edison
Miramar Florida
2024 Honda Civic Type R, 1999 Mitsubishi Eclipse GST
I parked under a tree at work and came out to this all over my car can anyone tell me what this is on it. I tried washing it and that didn't work also tried goo gone automotive and that did not work either does anyone know how to get it off safely without damaging the paint.
11th Gen Honda Civic Paint Issues Paint Issues
What kind of tree did you park under? Seems that whatever landed on the surface was acidic and caused a minor surface level etch.
Does your car have any pre-existing paint protection applied? If not, wash the area with liquid Dawn dish soap to remove the surface grease, wax, etc. Use a clay bar and lubricant to remove the contaminates from the surface of the paint. Clean the area again to remove any film and then reapply whatever wax or paint surface protection you prefer.
chuck76
Charles
San Francisco
You need a clay bar like blueroadster stated above. I always have a bar in the garage.
Blackbomber
Blackbomber
Edison
Miramar Florida
Ok thanks I’m going to try that and see if that works
SlowAP2
Terry
FL
25 CTR
Just remember with clay, it can put tiny scratches in the paint that may need to be polished off. It also takes off any wax or SiO2 (wont harm a real ceramic coating) so be sure to reapply something to protect the paint after.
I would not leap to claybar. This looks like tree fallout, a mixture of sap and pollen debris baked onto the paint. If a normal wash and Goo Gone did not remove debris, that means it has likely bonded to the paint or etched the surface. Start with the least aggressive method and graduate from there. Wash the car again and use a dedicated bug/tar/sap remover on the area in question. I recommend Gtechniq W7 Tar and Glue Remover or GYEON Q²M Tar REDEFINED. If these measures are unsuccesful, move to a claybar and then look to polish it out, if necessary.
Blackbomber
Blackbomber
Edison
Miramar Florida
I took the car to a car wash and they quoted me $150 to get that stuff off the whole car so I’m going to do that
marcusm86
Marcus
Missouri
2025 Civic Type-R
10 minutes of this on my car and now its stained... i wish i felt more comfortable with paint..
11th Gen Honda Civic Paint Issues 1783390438999-wf
That's unfortunate. It doesn't take long for the uric acid in bird droppings to eat through the clear coat. In this heat, it can happen in mere minutes. Unfortunately, it will likely need to be polished out.
marcusm86
Marcus
Missouri
2025 Civic Type-R
let me tell you.. hot water... all of the spots that have poo on it in that picture had a cloudy spot - even the splatter stuff. hot distilled water onto a microfiber cloth over the area for 5-10 min. These two pictures were the spot after the trial run - it was reduced down to a 1/3 the size and a lot of the spray was gone too. I cant get you a picture of the marks not there but they are 99% gone after the second round of the hot water treatment.
EDIT: Sorry didnt mean to hijack ur thread - im done here.
11th Gen Honda Civic Paint Issues 1783398173861-ev
11th Gen Honda Civic Paint Issues 1783398182878-2g
