Only_Sonic.SI
Rai
Carslbad, CA
2022 Civic SI 1995 MIts Vr-4
Does anyone knows stock tune PSI?
Ktuner 23 PSI vs Phearable level 2 a big difference?
kanav
Kanav
Toronto, ON
2022 Civic Si Black
I think stock supposed to be 16psi in certain conditions, I only ever saw 14 tho, there is a big difference between ktuner 23 and map 3 on phearable, map 2 and ktuner will be a smaller difference but i’d still take phearable over the basemap, the basemaps are specifically made to be on the safer side
mbaapk
Twin Cities
Pacifica
How does it disable rev hang? Isnt it a product of heavy flywheel?
kanav
Kanav
Toronto, ON
2022 Civic Si Black
On the stock tune watch the rpm when you push the clutch pedal in, it will hold current rpm for 1 second before it begins to drop, that is the artificial software induced rev hang to reduce vehicle emissions, after you put rev hang disable tune on and press clutch in the rpm will begin to drop immediately
The actual speed at which the rpm drops is a mechanical rev hang which can only be changed by changing flywheel/clutch
HRC
NE
Step 2 McLaren 570S
Doesn't the 1.5L take 87 octane? As in Premium fuel is only "recommended" but not required.
If so, what is the increase someone can expect on regular pump fuel, not 91, not 93.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
91+ is recommended for any tune. I'd highly advise against using 87 at all, but at least stay on the factory tune if you do.
