qingcong
- Joined
- Nov 29, 2023
- Threads
- 9
- Messages
- 78
- Reaction score
- 138
- Location
- North Carolina
- Vehicle(s)
- 2024 FL5, 2013 Si, 1991 NSX
I washed the car then dried it,
Then used Griots iron remover,
Rinsed it off then repeated,
Iron removed again then rinsed,
Used the Meguairs clay bar kit on the whole car,
Then dried for a final time and applied a Full Meguairs Ultimate Wax.
Super happy with the results and don’t think ceramic will make it any better. Just make it so I don’t have to wax. But at a high cost.
I put on some 3M PPF on my old Si in 2014 and took it off in 2023. It had yellowed quite a bit. The yellowing was not noticeable when it was on the car (sunburst orange pearl), but was definitely noticeable when I took it off. I was able to remove it myself as an amateur, no special tools or anything. They claim newer PPF is much better as far as longevity, but obviously not enough years have passed in the 2020 era for anyone to know for sure. Also, you can wax or ceramic coat on top of PPF, which should help it last longer.
For wax vs ceramic coating, I don't see any reason to do wax anymore. Prep work is basically the same. Ceramic will last a whole lot longer and protect better. The ceramic bottle itself is probably $50-80 which will last 1 application, vs a thing of Turtle Wax for like $10 which will last a few times, but the result is way better. You also don't have to worry about ceramic coating getting on the plastic or rubber bits and discoloring them. If you miss having things to do to your car, they recommend applying that topper stuff to ceramic coatings, which would take the place of waxing.
