Rear brake pad change question
surftheweb
Indiana
Civic
I've seen some conflicting information regarding retracting the rear brake caliper piston during a pad change. If you first put the rear brakes in maintenance mode using an OBD tool, then do you push the caliper piston straight in (as shown in the service manual) or do you spin it in (as shown in many online tutorials)? Or does it matter at this point? Thanks!
Service manual says to just use a generic tool to push them in:
11th Gen Honda Civic Rear brake pad change question tool
Most tutorials say to use this type of tool to spin them in:
11th Gen Honda Civic Rear brake pad change question tool2
Bugzy2
Stephen
Dubai, U.A.E.
2023 Honda Civic Type R, 2009 BMW M3
I just did mine. No need to spin. I just braced it in with the old pad. It didn't require much force.
Confirm, just push it back
Sooner1
Adam
Kansas City
Do you actually need to put it in maintenance mode? Never had to do with with any other car in the past. Audi's say you have to but you don't.
Gansan
Glen
San Diego, CA
1999 NSX, 2024 Civic Type R
You should do it. You can get away with it if your old pad has some thickness left because you're squeezing the new pad within the "slack" that exists when the parking brake is disengaged. But to do it right and reset the ratcheting mechanism, putting it into maintenance mode is better.
Edit: @MooMoo below is also right, you can manually crank the mechanism back. Forgot about that
you don't have to put it in maintenance mode if you do it the manual way (which is also described on the honda manual), you just remove the parking brake mechanism which is super easy, wind it back) then do what you have to do, bolt the mechanism back in and done.
But yeah if not done in manual mode I would def put it in maintenance mode.
surftheweb
Indiana
Civic
Great, thanks for the confirmation. After putting it in maintenance mode, I will straight push it back.
I have one more question where there seems to be some differing info out there. This is related to what, if any, greases or lubricants to apply to the caliper/pads for a Type R. The service manual explicitly goes out of the way to specify NO grease or lubricant on the Type R brakes while the other models do call for it. See below. However, most guides online do say to use grease.
Service manual no grease on Type R - g(*3)
11th Gen Honda Civic Rear brake pad change question brake2
Brembos and a lot of brake brands don't call for grease on pads, also if you track the car its pointless as the brakes will get so hot it will probably just crumble away quick (why I never put it on my cars cuz they all see track).
It is interesting that they say no for the type R because I am pretty sure the rear pads did have some stuff on them, fronts were installed dry (not surprised because brembos). I would just install dry specially if the manual says so
scuderia_miso
Teddy
Pacific Northwest
FL5, AP2
This is how I do it too. It is 2 extra bolts and doesn't require a fancy OBD scanner.
This dude explains it pretty well:
Nice, good to have videos. I did remove the cable to the parking brake which I dont think this dude did. Maybe not needed but I like to do it (btw that cable can be a pain to remove till you figure out how to do it).
there is another good video on youtube on how to do this, I think dude is on a fk8 on that video
johnloov
John
this is a good video on it
You DON'T NEED TO - remove the parking brake assembly or purchase an OBD2 scanner to put your rear brakes into service mode to change the pads!!!!!!
Fellas, all you need to do to change your rear brake pads is to NOT put your rear hand parking brake ON - That's it! Leave your car in first gear, and some wheel chocks.
I just did my brake pads - I can't believe everyone is instructing everyone to disassemble the rear brake OR get an OBD2 scanner.
I was like - this makes no sense, and just changed my rear brakes simply by shutting down my car, leaving it in first gear, and not applying the Parking brake.
This video also shows you how - Common sense...... Am I missing something?
pss. he's not using the brake compression tool properly - you want to use an wrench on the bolt and twist at the same time in opposite directions.
johnloov
John
Disassembling parking brake or using an OBD2 computer is not needed.
Here are my steps:
1) Don’t put parking brake on, and keep car in first gear. Wheel ch for safety.
2) Take two 7mm hex screws off and metal clip
3) Crack open brake fluid reservoir, screw back compress brake piston (grease occasionally seal)
4) Drop in pads, screw back 7mm (grease occasionally bolts)hex, metal clip insert
Done
11th Gen Honda Civic Rear brake pad change question IMG_3762
11th Gen Honda Civic Rear brake pad change question IMG_3763
11th Gen Honda Civic Rear brake pad change question IMG_3766
11th Gen Honda Civic Rear brake pad change question IMG_3769
