Rear vents/USB port mod
Nothing
2023 CW FL5 #5044
I still got the mikstore kit + the oem vent because of the fitment and the modifications that needed to be done to the kit doesn’t really fit the way it supposed to. I pay 273.12 for the kit and 141.47 for the oem parts but I bought couple of bolts and clips extra that I did not use. Because I look for the oem parts ant the part that diverts the air isn’t sold separately from the heat core or the part that is under there it was expensive. But all works perfectly for me and the shipping was fast for both mikstore I got it like on 3 days after I ordered and the JDM Yamamoto like 5 days after order.
It is unfortunate to need the extra $$ for good fitment, but the trim instructions weren't super clear (mikstore seems to update product/instructions continuously). I broke a clip or two and if I needed to reorder the vent panel, OEM might be a good choice. Mikstore did ship pretty quick though.
I would hope clips on the jdmyamato version are stronger, but mikstore also seems to use Honda OEM parts, so just less risk since it "fits" correctly. I broke clips in other places in this install too so take it with a grain of salt ?
Overall as mentioned before, it is barely noticeable and it doesn't move, so I'm ok with how mine went. I did have to open up the console again to do shifter upgrades and really tried hard not to touch this back panel.
Stanleywinthrop
Usa
10th gen
Question for those who have completed this project. Did you use the 2 piece or one piece duct from the front console to the rear? Of the individuals on this thread who have ordered JDM parts instead of or to supplement the mikstore kit it seems one went with the two piece duct and one with the one piece duct.
Does it matter which one we use? Does it matter according to the platform (Type R v. Si, etc)?
Nothing
2023 CW FL5 #5044
I just used the mikstore kit on my FL5. It used a new splitter at the front, a funnel shaped piece to connect it to a tube going back, a piece to go up to the new register, and a new rear console plate with register.
I'm not sure which other trims are different, sorry.
ajgrinds
United States
Installed the milkstore kit, had a gap that I couldnt get to go away, bought the OEM rear panel, gap is gone.
However, the air vent doesnt fit in the oem rear panel so now buying the OEM air vent...
Edit: Just kidding its $74 Im going to try to make the milkstore one work.
Mrjustin81
I just ordered this today for my FL5. Will see how it goes whenever it gets here. However long that’ll take
ajgrinds
United States
Update: the milk store vent doesn’t fit in the oem housing. What to do now… the oem housing fitment is much much nicer than milkstore
11th Gen Honda Civic Rear vents/USB port mod IMG_1991
turbolag
Anthony
South Carolina
type r
I have have the mikstore kit installed with rear jdm housing. I ended up using a dremel on the inner part of the jdm housing to allow the vent to fit flush. Definitely not what i was expecting to do but it turned out well in the end. After trimming, the screws are able to adequately hold the vent to the housing pretty flush. I also used some electrical tape on the inner part of the usb opening to hide any gaps around it.
ajgrinds
United States
Ok. Okay, we'll be waiting for your news. Good luck
Just installed. Took about 2 minutes. It’s perfect.
However, it’s now cost me like $150 more than the milkstore kit. I don’t know if going back I would do it. I’m glad I did, and it looks really nice, adds a needed feature to the car, but unsure if it’s worth the $400 I’ve spent at this point.
onepointsix
Toronto
TW FG2 & SGP FL5
That's how I looked at it with the rear vents. The cooling in the rear seems to be sufficient enough without them, though it does a more premium touch to the car. I opted to just go with the USB ports at the rear, just spent just over a $100 to get the parts from my local Honda dealership, and a little DIY with the harness.
11th Gen Honda Civic Rear vents/USB port mod IMG_0568
Mrjustin81
How long did it take to get your order from mikstore?
coldradio1
Oliver
Nashville, TN
Do you have a list of the part numbers that you used? What was involved for the wiring?
onepointsix
Toronto
TW FG2 & SGP FL5
Yup -
Rear Cover - 83451T20A41ZA
USB Ports - 8A350T20A01
Harness - 32114T20A10
As far as modifications go, you’re essentially cutting off the end connector that supposed to go to a port in the automatic shifter area on base civics. We’re extending the wire to go the cigarette lighter harness to get the 12V need. The USB port converts the 12V to 5A used for our mobile devices, so there no concern of damaging ports on phones/tablets.
If you need pictures, I’ll take some and post them up here.
