Rear vents/USB port mod
coldradio1
Oliver
Nashville, TN
Yup -
Rear Cover - 83451T20A41ZA
USB Ports - 8A350T20A01
Harness - 32114T20A10
As far as modifications go, you’re essentially cutting off the end connector that supposed to go to a port in the automatic shifter area on base civics. We’re extending the wire to go the cigarette lighter harness to get the 12V need. The USB Port converts the 12V to 5A used for our mobile devices so there no concern of damaging ports on phones/tablets.
if you need pictures, I’ll take some and post them up here.
Pics would be awesome! Thanks!
onepointsix
Toronto
TW FG2 & SGP FL5
Apologies for the delay, picture and quick explanation below:
Below is the 12V/Cig liter connector
11th Gen Honda Civic Rear vents/USB port mod IMG_7136_1.JPEG
The harness you get from Honda is short and the connector doesn't work with the FL5, so you'll need to cut the unusable connector off and lengthen the harness to reach the Cig lighter wires.
When you cut off the unusable end, it’ll leave you with 5 wires. You’ll need to combine 3 of the 5 for power and the two for ground. Grey, Orange and Brown are Positive, Black and Blue are Ground.
Once you have them combined, lengthen both wires and tap into the positive and ground wires for the 12V/Cig Ligher (Black is ground, White is positive). I used electrical tape and some lom and ran the wire to through the shifter assembly to the back. I zipped tied it to existing wire while running it through some it’s not laying around loose.
11th Gen Honda Civic Rear vents/USB port mod IMG_0576.JPEG
11th Gen Honda Civic Rear vents/USB port mod IMG_0577
Run to the end and plug into the USB hub and snap everything back together.
11th Gen Honda Civic Rear vents/USB port mod IMG_0578.JPEG
edido
CA
DE5
@onepointsix
Thanks for sharing the parts and photos.
Any idea if USB-C ports part exists? I tried to search, but looks like only USB-A ports part is available.
onepointsix
Toronto
TW FG2 & SGP FL5
@onepointsix
I know the MikStore has a USB C option, but I don't think the same harness will work. Whereas Mikstore will give you a "T" adapter that goes into the Cig light for the USB A ports, the wiring is apparently different for USB C ports.
EDIT: Link for the Mikstore
https://mikstoreph.com/collections/...ies/products/civic-2022-rear-ac-panel-usb-kit
edido
CA
DE5
It's weird, because they don't offer harness for USB-C Honda Original.
11th Gen Honda Civic Rear vents/USB port mod Screenshot 2025-06-09 at 6.04.22 PM
edido
CA
DE5
My bad, looks like the do sell USB-C Harness:
11th Gen Honda Civic Rear vents/USB port mod Screenshot 2025-06-09 at 6.16.07 PM
Seems like what I need:
1. Rear cover from any Honda dealer shop - 83451T20A41ZA.
2. USC-C + USB-C Harness from Mikstore.
onepointsix
Toronto
TW FG2 & SGP FL5
Yeah that's what I was thinking.
edido
CA
DE5
My car is ITS DE5. Seem like Integra A-spec with tech package comes with USB-C:
(scroll to 6:35)
This is the OEM USB-C:
https://acura.oempartsonline.com/oem-parts/acura-usb-port-8a3503t0j01
This is the EOM harness:
https://acura.oempartsonline.com/oe...onsole-321143k0h00?referrer=acuraparts365.com
This is the EOM panel:
https://acura.oempartsonline.com/oem-parts/acura-rear-cover-83451t20a41za
It might fit CTR also, but can't tell for sure.
I didn't find instructions or video of how/where to connect the harness. I will keep looking and probably will call a dealer.
onepointsix
Toronto
TW FG2 & SGP FL5
The connector looks similar to the one I picked up for the Civic. It seems like the if the front connector doesn't exist, you'll need to extend the wire and tap into the 12V connector like I did.
edido
CA
DE5
You are probably right. I asked one of the guys I know from a nearby dealer to get me a list of parts used in the Integra A-spec with tech package. If he can get the list, it will be ideal.
edido
CA
DE5
I ordered the following parts per confirmation from a local Acura dealer. They can't confirm it would work, but also don't see any reason why it would not work :dunno:
Rear cover: 83451-T20-A41ZA
Harness: 32114-3K0-H00
Dual USB-C port: 8A350-TJB-A01
Anyway, I will update here after I receive the parts and try to install.
onepointsix
Toronto
TW FG2 & SGP FL5
Were you able to get this working?
