Spying on you?
Super easy removal of the TCU. Use a plastic pry tool to remove the center speaker cover (5 retaining clips) to access the TCU:
11th Gen Honda Civic Spying on you? 1741323313454-29
Remove the two screws on the metal mounting bracket to pull out the entire unit:
11th Gen Honda Civic Spying on you? 1741323619734-tm
Disconnect and tuck harness connections (temporary solution):
11th Gen Honda Civic Spying on you? 1741323673696-s2
Reinstall center speaker cover and you are done. No more cellular communications beaconing back to the mothership.
I would also say that given the industry and where things are headed (e.g., Smart Cities), don't interpret this as a knock on Honda for embedding telemetry. Every auto manufacturer has been compelled in that direction in the sense that daily drivers are apparently looking for more convenience features (e.g., live traffic congestion updates, cheap gas prices, the nearest Starbucks location, etc.). What drivers likely may not know is how much other behavioristic data is actually being collected.
The FL5 has a TCU providing cloud-based connectivity crap but at least that form of connectivity can be easily severed without negatively impacting other control units on the CAN bus.
Nanook
JP
Chester, VA
@blueroadster Be sure and report back any issues you run into. I’m looking to do this, but it will a couple more weeks before I can.
No unexpected issues at all. Everything still functions normally, navigation, traffic maps, etc. Occasionally after startup, you'll briefly see a red satellite icon appear on the top right of the screen.
With the TCU removed:
  • The vehicle is no longer pushing data to the cloud.
  • If you have the HondaLink app on your phone, it and the mothership can no longer see the vehicle (e.g., vehicle recovery feature is lost).
  • Obviously, WiFi Hotspot no longer functions as there is no cellular modem.
  • You lose the ability to receive notifications of system updates that are sent via the cellular connection. Instead, you'll have to occasionally connect the car via WiFi to check/install updates or install updates via a USB thumb drive.
  • I would not recommend connecting your phone to the vehicle as that would offer a secondary communications link back to the cloud and mothership.
Here are several PICs:
11th Gen Honda Civic Spying on you? IMG_1128
11th Gen Honda Civic Spying on you? IMG_1129
11th Gen Honda Civic Spying on you? IMG_1131
11th Gen Honda Civic Spying on you? IMG_1132
11th Gen Honda Civic Spying on you? IMG_1133
11th Gen Honda Civic Spying on you? IMG_1134
11th Gen Honda Civic Spying on you? IMG_1136
Both! ? Thank you for the information! Everything in the infotainment and CarPlay/AA still work normally without the TCU connected?
Yes, CarPlay and AA still work perfectly fine if you have those connections configured.
Thanks for all the legwork on this! You seem to be well versed in these systems.
I’ll be doing the same when my car emerges from hibernation.
NP and happy to help although vehicle telemetry is not my cup of tea. I researched it in the past before I bought a 2020 F-150. That particular year was an early iteration of a "connected" vehicle where it was easy to disable power to the embedded AT&T cellular modem by removing one connection point of a three-pronged fuse to kill power to it. That was a simple fix that had no issues with any other control systems. The 2021+ F-150 on the other hand, has an integrated TCU (similar to OnStar) where if it is removed, other control units on the CAN bus pitch a fit and generate odd malfunctions/problems.
Thankfully, the FL5 TCU (at least through model year 2024) is not imbedded with other control units. The TCU can be removed without issue or causing pain to other "convenience" features.
I expect "reasonable expectation of privacy" in life rather than the "opt-out" mentality.
blueroadster, do you have any pics of that '64 Impala?
Previous owner let the car sit for 20 years before finally deciding to sell. All stock with the exception of the exhaust and transmission (swapped out for a Turbo 400 by the original owner). Has a 283 V8 in it but I also bought a 396 V8 from a friend that fully built the engine as a spare for his 1967 Impala. The 396 was over bored to a 406 pushing over 500HP at the crank.
11th Gen Honda Civic Spying on you? IMG_0257
11th Gen Honda Civic Spying on you? IMG_0255
11th Gen Honda Civic Spying on you? IMG_0260
11th Gen Honda Civic Spying on you? IMG_0259
citrus
My small contribution: If you decide to remove the ASC completely from your car, you can route the ASC cable up to the hole behind the screen and tie up all three cords together to prevent rattles.
11th Gen Honda Civic Spying on you? 20250314_232618
Nice job...Better to be disconnected rather than continuing to feed the lurking monster. No more "vehicle telling a story about its owners and its journey" kind of crap mentioned in the opening of this video link:
vimeo.com/657856771
Vision of the future reminds me of Demolition Man.
