sikkwititt
How does it ride?
First time going the springs route so it was all new to me. The first two weeks had me regretting cause it was super bouncy. Then basically after they settled it was night and day. The ride is very close to stock. On corners you can really feel how planted the car is.
Definitely recommend swift if your going the springs route and pair them with some spacers for that fitment.
1. Year and Model:
2. Wheels and Offset:
Front: 19x9.5 OEM Matte-Black Alloy, ET +60
Rear: 19x9.5 OEM Matte-Black Alloy, ET +60
3. Tire Brand and Size:
Front: Michelin Pilot Sport 4 S 265/30ZR-19 93Y XL
Rear: Michelin Pilot Sport 4 S 265/30ZR-19 93Y XL
4. Suspension:
Swift Springs
5. Wheel Spacer Brand, Type, and Size:
Front: BONOSS Forged Lightweight Plus AL6061-T6 20mm
Rear: BONOSS Forged Lightweight Plus AL6061-T6 25mm
6. Clearance (i.e., Does it rub? If so, when?)
Front: N/A
Rear: N/A
7. Wheel Studs
Front: Stock
Rear: Stock
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_5751
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_5764
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_6023
mbaapk
Twin Cities
Pacifica
1. Year and Model:
4. Suspension:
Swift Springs
Front: N/A
Rear: N/A
7. Wheel Studs
Front: Stock
Rear: Stock
Its a perfect look really. Do you notice a sharper turn in?
keonigt
Keoni
Hawaii
2024 Honda Civic Type R
1. Year and Model:
4. Suspension:
Swift Springs
Front: N/A
Rear: N/A
7. Wheel Studs
Front: Stock
Rear: Stock
Ride looks good!
Did you cut the bump stops when you installed the swift springs?
arcticdc5
William
Freshly installed this afternoon. Debating if I should have went with 20mm on on all corners, or if the look will get better once I install the lowering springs. From the tire sidewall to front fender edge is 1/4" protrusion, rear is 5/16" protrusion using a level and tape measure. Still can't make up my mind if I should put 20mm on the rear or not.
1. Year and Model:
4. Suspension:
OEM
Front: N/A
Rear: N/A
7. Wheel Studs
Front: Stock
Rear: Stock
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread overall2
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread overall1
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread side4
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread side3
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread side2
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread side1
Sakura_FL5
Ali
Atlanta
2023 Championship White Type R
Hi all - thanks for this informative thread. Looking to install spacers on my car soon. With regards to alignment, did you all keep it at factory specs? I think my car is due for an alignment anyways so will likely get this done with the spacers and just curious what others have done here.
No alignment for me. It's not necessary for spacers.
FL5Charlie
Charles
San Diego
Hi there! This is my first post on this forum and I have to say that this thread has been very helpful. Just got my Championship White Type R a few months ago and currently have 3k miles on the odometer and the first things I’ve done already was install swift springs and spacers. So grateful to get a glimpse of what people are running and the outcome on my Civic is perfect! The Swift springs are on point with ride height and handling and the spacer choice pushes the OEM wheels out just perfectly WITH NO RUBBING!
Direct plug and play with NO NEED to modify a single thing.
1. Year and model:
2. Wheels/offset:
3. Tire size:
4. Suspension:
Swift Sport Springs Spec R for the FL5
5. Wheel Spacer Brand and Size:
Front: BONOSS 20mm
Rear: BONOSS 25mm
Front: N/A
Rear: N/A
7. Wheel Studs
Front: stock
Rear: stock
8. Insert photos
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_4625
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_4626
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_4627
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_4629
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_4630
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_4597
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_4595
Dodif
Dodif
Round Rock
Just saw that Aeroflowdynamics released their own 20mm wheel spacers. Interested to see how they are.
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread image000000
That's too bad these come in a set of 4 spacers as you would have two purchase two sets if you didn't want to run a square set up.
Dodif
Dodif
Round Rock
True. But cheaper than the Bonoss overall. In my case I'm just gonna go for all 20mm. But from what I can see, these from Aeroflow seem pretty decent compared to the Bonoss correct? As far as material goes?
