TYPE S ADS INSTALL - THE EASY WAY
TheFactor
Factor
So Cal
2025 CW Civic Type R
To be honest, I haven't really noticed a difference. I am, however, going to the track in 3 weeks, and there are some key areas on the track where the car is incredibly bouncy. I'll be able to report back afterwards.
A few guys I know swear that it feels softer and more compliant, but that it's only most noticeable in comfort mode. Well...I don't use comfort mode. I want to see how it does in +R.
That makes sense since you’re more track oriented with your FL5. I’m looking forward to your thoughts after your track sessions ??
I like R mode when I’m driving spirited on the streets “most of the streets” unless it’s really rough. Other than that I like it in comfort just cruising. When I first got the car a year ago it was RRRRrrrrrrrrr mode or go home lol.
Did you disconnect the battery ? I’m guessing it’s not necessary and didn’t notice it in your spy footage ?
I don't recall disconnecting the battery.
I believe that there is no risk of a short, just unplug the wire harness and plug into the ITS module.
that said, it does not hurt to disconnect the battery.
though once the battery is reconnected, the first few miles are a pain with all the systems re-calibrating/re-initializing and the associated warnings...
TheFactor
Factor
So Cal
Thanks brother I’ll probably take a gamble and not disconnect the battery.
I didn't for this. Just did it with the car off.
ILX6SPEED
GTA, Canada
'14 Acura ILX 2.4 (rip), '17 CRV, '25 FL5 CTR, '23 CX9
awesome vid, seems way simpler. Will swap my ADS module in a few weeks thank you!
Ok I wasn’t sure it was hard to see at times from that decoy smoke in the secret ADS stash box ?
Totally thinking about using the hazer to make fun of STI drivers.
TheFactor
Factor
So Cal
Not to go off topic on your thread but what’s your thoughts on the PRL Aluminum intake cover ? I’ve got mixed thoughts I bought it just for looks and thought it couldn’t hurt since it acts as a heat sink to dissipate heat. But man that thing gets pretty hot and I’m wondering if it’s holding heat more then dissipating it. Unfortunately I didn’t really note temps before and after.
11th Gen Honda Civic TYPE S ADS INSTALL - THE EASY WAY IMG_0927
Thinking it's probably more geared for looks than anything else.
