Underbody Service Panel
iamwaywong
Way
New Jersey
2007 SSM AP2, 2023 CW FL5, 2022 PW RDX A-Spec
Anyone else have trouble getting the screws off the service panel for an oil change? 2 out of the 4 came out smoothly and the remaining 2 screws towards the center of the car seemed to be completed ceased on my car. I had to drill out the heads unfortunately.
Anyone have tips on how to the get the remaining threaded portion of the screw out of the subframe inserts?
RP2000R
Sand and dirt can make it harder to remove screws/clips. I usually tap the area a bit and turn screws back and forth to ease them out.
iamwaywong
iamwaywong
Way
New Jersey
yep tried wacking them with a hammer and also spraying some WD-40. These screws did not budge! In the future I'll have to extract what's left if the screw body
Happened to me had to replace them, they were completely seized.
Nothing
2023 CW FL5 #5044
Sounds like I'll need to add to my list of hardware and clips to have on hand soon. Are these actual metal screws and not body clips? Clips always break and they're not cheap.
On previous cars I just ended up going 3rd party. Cheaper to replace them every time than pay 5x more and breaks every other time. lol
rBobby
Ricky
It is aluminum screws in to steel threads. I was able to get mine out with an impact driver. Put new ones in with anti seize.
Shrapnel
CW 2024 Civic Type R #16838
They really didn’t make it as easy as they could have to get access to that area on the FL5. I had a GR86 prior to my FL5 and miss how easy it was to change the oil on that car.
MSUGeoman
Josh
Tennessee
2023 Civic Type R #2486
Anyone have a source for replacements? One of my front screws went mia…
MSUGeoman
Josh
Tennessee
You can just use generic honda belly pan search and they should appear. I don’t have the part number with me but its where I found mine.
Nice, yep, lots of options on Amazon. Just ordered a complete set for 8 bucks, figure it’s good to have spares.
When you do replace the bolts, put some antiseize on them.
