Vacuum brake bleeder
Ic@ns33urhrt
Southeast
A car
Wanting to flush factory brake fluid. Wanting to switch to Castrol SRF. Looking at motive vacuum bleeder. Anyone have any experience with this one? Any recommendations on one? Thanks.
TDC50
Long Island NY
‘23 Type R, ‘24 GR86
Ic@ns33urhrt
Southeast
A car
I use a Motive pressure bleeder ’dry’. You buy the cap that fits your master cylinder, use the pressure bleeder to build about 12psi, and then work your way around the car to bleed the calipers.
A few times you depressurize and re-fill the master. Nice, clean and well controlled bleeding process.
https://www.amazon.com/gp/product/B000Q6SL2W/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B01MYXAXS5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Thanks for the input. Do you know what cap fits the fl5?
Bazgab
Rob
Raleigh, NC
I am giving the Speedi-bleed a try.
I have had a Motive speed bleeder for years but I don't love it. I have had issues a few times with the seal not holding and brake fluid going everywhere and also with the pressure container not holding pressure. I have MacGyvered it to work fine as issues have come up, but it is not my favorite.
keller
Somewhere south
2019 fc3, 2021 fk8
I recently purchased a bleeding wrench with a check valve. They are quite common with motorcycle guys, so it got my interest. If the seal works fine, it should be really fast to bleed the brakes. After all, I usually take longer to install the tubing in each bleeding nipple than actually bleeding the system.
Has someone used one of these before?
https://www.amazon.com/FIRSTINFO-Brake-Clutch-Bleeder-Wrench/dp/B09J1187CQ/
Yeah I've seen videos with the Motive and it looks pretty janky with setting and maintaining the pressure. I've read comments about people having the same problem
I looked at videos on how to use the Speedi and honestly it looks so much simpler with usimg the tire to maintain pressure. Its on sale right now for 35% off so it seems like a really good time to get it
Bazgab
Rob
Raleigh, NC
Exactly right on the Motive. It isn't terrible but it is sort of cumbersome to use and maintain pressure. 60% of the time, it works every time, haha. Maybe others have better luck with it.
Ic@ns33urhrt
Southeast
A car
Maybe a dumb question. But with the speedi bleed , do you have to put air back in your tire?
balucipher
Balu
Coral Springs, FL
2023 CW CTR
With the speedi-bleed I use this bottle at each corner to drain from the nipple
Allstar Performance ALL11017 Bleeder Bottle with Magnet and Check Valve , White https://a.co/d/hqhvpv4
A little hard to see the fluid, I would look for something like this but with more clear plastic to see the bubbles in the fluid
007
2023 GR Yaris - Circuit Pack
Who needs fancy gadgets when you can rock it old school and bleed the brakes like a boss? It's a lightning-fast, no-nonsense process that won't cost you a penny, as long as you have a trusty sidekick for a quick five minutes.
Personally, I enlist the unparalleled skills of my better half, and miraculously, it's the only time she willingly follows my every command. A true bonding experience, I tell you!
