ayospoonay
Glove up!Installed! Yup, everyone is right, it's so good. Much better than the leather steering wheel.
Or I just clean it regularly like I do the rest of my car.Glove up!
Nice pick up! The COBB Tuning piece is quite nice. They had an issue with the first run batch that they appeared to have properly addressed.Replaced my PRL HVI intake with the COBB Redline intake. The quality and attention to detail is very nice. I like how it comes with its own hood rubber seal and rubber bushings with nice aluminum spacer inserts. No reusing stock seals and bushings/spacer inserts. Even the rotating collar that locks the top access door has a satisfying "click" when locking it in place.
Previously tuned on Hondata OTS 91 map, the car does seem to be idling a bit higher now due to the bigger MAF tube diameter. It's huge, I believe I can fit PRL MAF tube into the COBB MAF tube. I'm stuck with which tune to go with? I see many people running Jester or Phearable e-tunes. How does it exactly work? I tell them my mods and they come up a custom map or are they off the shelf maps that puts out more power than the Hondata OTS maps? Do they come with data logging to see how it's running or that cost extra?
I'm not sure I understand the purpose of having a huge intake tube and having to mess with recalibrating your MAF. The only reason I can think of doing this is so that Cobb can sell you their tune to go with it. Unless you're going to a big turbo, you are still "necking" down to your turbo's inlet...so you're still limited by your turbo's inlet size.Replaced my PRL HVI intake with the COBB Redline intake. The quality and attention to detail is very nice. I like how it comes with its own hood rubber seal and rubber bushings with nice aluminum spacer inserts. No reusing stock seals and bushings/spacer inserts. Even the rotating collar that locks the top access door has a satisfying "click" when locking it in place.
BLUF: not limited or lower air volume. Necking down results in a higher velocity at the OEM pipe keeping air volume about the same.I'm not sure I understand the purpose of having a huge intake tube and having to mess with recalibrating your MAF. The only reason I can think of doing this is so that Cobb can sell you their tune to go with it. Unless you're going to a big turbo, you are still "necking" down to your turbo's inlet...so you're still limited by your turbo's inlet size.
Got the car detailed, just waiting for my Mugen lip to come in so I can finish it.
