- Joined
- Oct 19, 2024
- Threads
- 11
- Messages
- 671
- Reaction score
- 622
- Location
- Ventura CA
- Vehicle(s)
- 2025 FL5, 2014 Chevy Suburban (wife), previous 2007 FA5
My driving is similar to yours.I’ve been ready to pull the trigger on paragon rotors front and rear and brake pads but I’m stuck on pads.
I do not track but do hit the twisties a few times a year with friends. I don’t go too fast but I do go fast enough that I push the brakes some. I also have real winters and would appreciate something that will stop in the cold without making me freak out cuz she doesn’t want to stop for like the first second or two of applying the brakes. I dont care if the dust is minimized or crazy bad but would be cool if it’s minimized, I guess
I’ve narrowed it down to the paragon p3 pads, project mu HC (not the plus ones) and counter space spec cp pads. I just want oem brembo like performance with an ever so slightly higher temp range.
brake fluid will be the oem fluid for now. Till I can find something that can last me 2 years and performs better than oem, even if a little
thnx if y’all can kick in your two cents. Appreciate y’all
No track, Angeles Crest , Santa Monica and Santa Barbara mtns a few times a year
but about a mile of mild twisties daily on the way home (which I'll never admit to driving faster than 80mph)
for my research, I put more weight on pads that would grab better when cold, such as for emergency or panic stops. (vs race pads that grab best when warm/hot)
This is from my research notes, for when I'll need new pads or fluids:
brake pads
https://www.civicxi.com/forum/threads/brake-pad-manufacturer-model-compilation-thread.54351/
Hawk Performance Ceramic HB453Z.585 HB900Z.572
Hawk HPS 5.0 HB453B.585 HB900B.572
1. To break in the new components, make 6 to 10 stops from approximately 30 to 35 MPH applying moderate pressure.
2. Make an additional 2 to 3 hard stops from approximately 40 to 45 MPH.
3. DO NOT DRAG BRAKES!
4. Allow 15 minutes for brake system to cool down.
5. Your brakes are now ready for use and can be driven normally.
others to consider:
EBC Yellowstuff DP41210R DP42402R
Paragon P3 (bad review on CivicXI)
Paragon P2 "Sport Comfort" PBP.0370.150.P2 PBP.1557.145.P2 (least aggressive)
EBC Redstuff DP31210C DP32402C
Clutch / brake 1.5-2L
Bosch ESI6-32N Brake Fluid (DOT5.1)
https://www.amazon.com/Bosch-ESI6-32N-Brake-Direct-Replacement/dp/B07338GQM8
Dry Boiling Point: 270°C (518°F)
Wet Boiling Point: 185°C (365°F)
Change Interval: 3 years
ATE Original Super DOT 5.1 Brake Fluid
https://www.amazon.com/ATE-Original-Super-Brake-Fluid/dp/B08P1QYLNP
Dry Boiling Point: 265°C (509°F)
Wet Boiling Point: 180°C (356°F)
ATE Original TYP 200 Racing Quality DOT 4 Brake Fluid
https://www.amazon.com/ATE-706202-Original-Racing-Quality/dp/B003VXRPL0
Dry Boiling Point: 280°C (536°F)
Wet Boiling Point: 198°C (388°F)
Change Interval: 2 years (some sources say up to 3 years)
