SpoolinFK8
Gogi
NY, NY
2024 Honda Civic Type R FL5
Replaced the center console/shift boot, side, and center console trims with some Alcantara from Overland, along with a shift boot collar from Acuity.
Also received and installed my FL5 mustache from JAS. This is my first carbon part and the weight difference from the OE hood vent is significant.
Welcome to the Mustache family my friend.
11th Gen Honda Civic What did you do to your FL5 today? IMG_6388
Agen2integra
Evan
Philly
2025 CW CTR
Just installed my illuminated door handle and pocket lights. Ordered these from Black Hawk Japan a little while back , they were on a slight back order. I got them this past Thursday so I had to get em in this weekend! Part number for reference 08E20-T43-002B
11th Gen Honda Civic What did you do to your FL5 today? IMG_5873
11th Gen Honda Civic What did you do to your FL5 today? IMG_5874
[email protected]
If you’re in the US, keep in mind the 15% tariff + brokerage fee.
I reached out to them around the time the parts were released and haven't revisited it. How would you characterize the quality of the parts? How was the packaging when received? Also, what did you pay in tariff fees relative to your order total? Any regrets and/or what would you different if you had another crack at it?
@nojeebs
@Allthingsfl5
@Club Version
@R Tard
0x1d7
Washington
2025 Civic Type-R
Part is solid. There could be something to be said about fitment on the passenger side where it tapers off, but only if you go looking for it. Install was easy (put a blanket over the engine bay just in case you drop a nut).
It was shipped securely. Through FedEx I paid $220 for tariff + brokerage. Customs was a pain, having never had to fill out the forms before.
No regrets. Looks great and was a bit cheaper than the Spoon alternative for a carbon hood vent.
Club Version
Jose
www.youtube.com
FL5 Championship White
No regrets on my end! Parts came very well packaged and fitment was spot on for me. I did not use the mesh grill on the hood vent though.
Wogboy
Howard Ino
Sydney, 'Straya
2023 FL5 Type R
to the owners who have that annoying tinny sounding window rattle when the window is down approx where the angled piece meets the sail plastic trim
3 visits to the dealership and they still had no fix for it
so I winged it and worked out the rubber was hitting the metal when window was down at a certain point
I placed a 2mm thick rubber in between the rubber and metal and added some silicone rubber and presto.....ggg
ooonnnneeee
11th Gen Honda Civic What did you do to your FL5 today? Screenshot_20260708-000125
Thank you both for sharing your perspective. The parts look great! I just may move forward with picking up a few pieces.:hmm:
MrBBQ
Danny
What made you change over? I'm tempted to do the same just for the easy access to the filter.
I got it for a really good deal, couldn't pass it up. I'm doing a custom tune anyways even if I had the PRL, so it works out.
The reason that I got the @COBB Tuning intake was because it is CARB compliant, and I wanted more air/power so I also got the Cobb jailbreak and Access port with custom tune by Brian @JST Performance
I am very pleased with both.
the custom tune is still an iterative work in progress, it is taking a long time because I keep forgetting (so good as is) to log and send Brian the logs he needs for the next iteration.
Highly recommended.
some more details here:
The Cobb intake substantially lowers overall intake restriction before the transition to the narrower ORM pipe which enables higher total mass airflow.
Fluid dynamics: For air treated as incompressable at typical intake pressure and velocities, the volume flow rate Q is the same
Q = A1 x v1 = A2 x v2
where A1 is the larger Cobb MAF housing area and A2 the smaller OEM area.
Plain English: the diameter reduction from the larger Cobb MAF housing to the smaller factory turbo inlet pipe increases local air velocity in the narrower downstream section while the larger volume flow rate remains approximately the same through both sections under steady flow conditions.
Also the Cobb velocity stack geometry combined with an integrated straightener grid produces a uniform less turbulent velocity profile at the sensor element. The result is more precise and repeatable mass airflow readings than the stock configuration provides.
The proof is in the pudding.
No dyno, but I can easily break traction in 2nd. 3rd gear pull is awesome too
Grin inducing every time I drive.
[Edit] Forgot to mention that the Cobb intake makes both the turbo whoosh on acceleration and the bypass valve discharge psht sound on lift-off noticeably louder than the stock intake, adding to my grin [/Edit]
The first time I came home my wife asked me "what's that silly grin on your face?"
I still come home with a grin on my face, and she still doesn't get it.
Also the gas mileage did not suffer.
What's not to like?
DmK
2025 FL5, Mx5 ND3
Highly recommended.
Makes me wonder, how does it effect temperature inside of inlet pipe.
My understanding, since COBB has a bigger MAF Housing it forces more air compression inside of factory inlet pipe, as a result, rise in a kinetic energy directly causes air temperature to increase, which can effect turbo energy output :hmm:
the larger MAF housing in the Cobb Redline does not force extra compression or raise temperature inside the stock inlet pipe
it reduces upstream pressure losses, and the velocity drops in the enlarged MAF section, which lowers frictional losses before the air reaches the turbo
the irreversible losses that would convert kinetic energy into heat are minimized by the velocity stack and straightener grid
although velocity does rise again in the factory diameter pipe, the overall result is higher absolute pressure at the compressor inlet than with the stock intake
Cobb has shared test data showing the airbox pressure stays closer to ambient which lets the turbo reach target boost with less wastegate duty, lower exhaust manifold pressure, and better efficiency
i.e. the intake flows more air with less restriction and helps the turbo work more easily rather than against added losses
in fluid dynamic terms, Bernoulli’s relation for steady flow shows that lower velocity in the large MAF section corresponds to higher static pressure there for the same mass flow
the smooth contraction that follows raises velocity and lowers static pressure, yet the total stagnation pressure delivered to the compressor remains higher because upstream losses have been reduced
for typical intake velocities the associated temperature changes are only a few degrees and do not meaningfully affect compressor inlet conditions
in short, the design improves turbo efficiency rather than creating additional work for it
https://www.cobbtuning.com/products...nda-civic-type-r-fl5-acura-integra-type-s-de5
artsyfartsyFL5
Ant
PA
www.instagram.com
2025 CW FL5
Highly recommended.
Ironically, PRL's intake is now 50 state CARB legal in 50 states, but im glad to hear positive things about the Cobb, especially coming from Subarus.
