Geraldfl5
Gerald
Pittsburgh
2023 type r 2003 Vw Passat wagon
wish you were closer to me in PA, I wanna hear this in person so bad since I'm torn between this and the AWE track. I want the louder option lol
I like the milltek with the valve louder then stock but not to crazy but with the valve open it get louder
SpoolinFK8
Gogi
NY, NY
2024 Honda Civic Type R FL5
Has anyone had any experience with the Pulstar Plasma Core Spark Plugs? Just received my set yesterday. Will be installing them soon.
Received shipment of the Fujitsubo exhaust and front pipe today. Here is the exhaust section:
11th Gen Honda Civic What did you do to your FL5 today? IMG_1711
I don't have a lift, so instead of using jack stands, there is enough clearance using ramps.
11th Gen Honda Civic What did you do to your FL5 today? IMG_1710
Mobias
2024 Civic Type R, 2006 S2000
Received shipment of the Fujitsubo exhaust and downpipe today. Here is the exhaust section:
I've heard this is not much louder than stock on highway. I'd definitely like to hear thoughts!
Mrjustin81
11th Gen Honda Civic What did you do to your FL5 today? IMG_6783
Let there be A/C haha
Other than my not noticing the little tabs as I got fit really good otherwise. Not going to try to remove and get back in the same fit. Might try to trim those off.
I installed the Fujitsubo front pipe and exhaust this evening. I decided to just drive up onto two ramps in the front and used two jack stands in the back. Access was cramped without having enough space to use a creeper but overall, the install took about 2 hours to complete from start to finish. Everything lined up perfectly.
@Clark_Kent already shared detailed information and PICs of the Fujitsubo front pipe and exhaust in this post. Here is his follow up post with sound clips after installing while using the using the OEM downpipe.
My car has a TSP downpipe installed. Sound during a cold start has a deeper tone but around the same dB level.
Brittania
Brian
North Carolina
2024 FL5
These are the numbered plates located on the dashboard, in front of the co-pilot.
Oh OK I thought they were badges to go on the valve cover. Would you be able to scale that design to a plate that is 90mm wide by 24mm high? Would be awesome!!
11th Gen Honda Civic What did you do to your FL5 today? 20250425_083443~2
