DSC suspension controller feedback/experience on a stock CTR FL5
lflouie
jeff
Knoxville, TN
Audi S4, Audi A4
Recently installed a DSC unit on my stock 2025 CTR a few days ago and couldn't be more pleased. Thought I'd share my INITIAL experience with an "off the shelf" programmed DSC controller on a stock unmodified CTR suspension used in the REAL WORLD.
Bottomline: Works great as a plug and play drop-in on stock suspension CTR FL5.
Journey:
Nearly purchased a first release Acura Integra Type S (2024) but felt the car lacked the "edginess" and overall handling I sought, it leaned more towards a sport sedan characteristic than an aggressive and nimble handling backroads rocket (hatchback). I was seeking a weekend car to fulfill what my Focus RS had done so well....uncompromising handling and grip with a solid chassis and good power delivery.
I was willing to buy my first ever high performance FWD car based on the reviews and feedback, but the ITS fell short on my priorities list for handling and aggressiveness, so in Dec 2025 I bought my new CTR and commenced with assessing its capabilities and limitations. Right off the bat there were so many things to love about it...incredible grip, no roll/flat cornering, exceptionally flexible power delivery, factory drive modes that actually provided meaningful differences and were customizable, near perfect seats, a very good shifter (not perfect, but exceptional), wonderful steering weighting, ....and more. There were a few annoyances including: a ridiculously small fuel tank capacity (12 gal), no spare tire, uninspiring exhaust sound, and a suspension that while competent was almost only useable in COMFORT setting for anything else but a glass smooth road/track surface. So like the Focus RS, it had multiple suspension settings but only one that was practical for non-race use. My conclusion was the CTR was the right car for me, but it slightly missed the mark on the suspension based on my priorities and use.
I had installed 2 DSC modules, first one on a 2007 911 Turbo (6spd) with the early version of OEM "adaptive suspension:, and the second on the Focus RS. Ibought the 911 in 2017 and was transformed by the DSC module, which had been around for at least 5 yrs at that time. The module had been thoroughly adapted and tuned for the car, so I did not need to customize the programming. the module took away the roughness of the OEM system, and provided an amazing amount of drivability, grip and civility when bolted in. The only additional tweaking that was required was adding a slightly stiffer rear sway bar to aid turn-in and low speed tight cornering control.
The Focus RS experience was different. The RS was known for its stiff and harsh suspension, especially in the "sport" setting.....normal setting was marginally better but punishing and ill balanced for most driving situations except aggressive situations. Since the Focus RS was a new suspension design, and the early 2016 car was unproven, it took a series of evaluations to identify what was needed and to find the right parts to change to improve the car. The DSC module was not available until the following year, so my series of changes included lowering springs (Mountune), larger rear sway bar, second generation (softer damped) rear oem shocks, aggressive alignment (camber), and different wheel offsets made the "Normal" setting a very usable, but firm, suspension setup. When the DSC module came out I was one of the early version users. It didn't have the benefit of several yrs of development and software optimization to be effective as a "drop-in" solution. I tried it without programming it and was disappointed with the results...excessive push and poor roll control. I never tried to "tune" it but others did and after a while the module earned acclaim from many owners.
When DSC started delivering the CTR/ITS module in Dec, I had mixed feelings based on my prior experience, especially on a newly released suspension model for a relative new platform. I decided to try it on my CTR and here is what I discovered.
Background:
* Car: 2025 CTR with 1030 miles on stock wheels, tires, suspension and alignment.
* Type of driving/use: primarily a weekend car with emphasis on high levels of street performance on twisty backroads/mountain roads (frequently on the Tail of the Dragon).
* Environment: car will never see a race track but will be driven on a range of road types and conditions.
* Owner: many yrs of owning a range of high performance cars from Europe, Japan, and USA...most recent cars including: Focus RS (modified suspension), 911 Turbo (modified suspension), Audi S4 (modified suspension), Alfa Romeo Quadrifoglio, S2000 (modified suspension), and Subaru STI (2) (highly modified suspensions).
* Suspension experience: ranging from full custom coil-overs and off the shelf coil-overs, lowering springs, chassis bracing, U/L control arms, swaybars, bushings/inserts), and previous DSC controllers (911 Turbo and Focus RS).
Before starting the installation/evaluation, I drove the car 900 mi for break-in, but during break-in I cornered the car aggressively to let the suspension, bushings and tires fully break-in. I have owned many different Michelin tires of all varieties, and the rule of thumb is it takes 700 to 1500 miles to break-in the side walls on these tires before they truly lose their sidewall harshness. ...the same is usually true for suspension bushings, thus trying to evaluate a suspension before 1000 miles is difficult.
Observations/results:
Initial impression driving out of driveway was:
* In Comfort setting the car felt overly bouncy over undulations in the pavement at low speeds (< 35mph).
* The steering felt less urgent (turn-in) around town
* The ride was improved (softened) significantly reducing road imperfections from imposing to subtle, and taking the "harsh edge" off of large irregularities.
* A more lackadaisical overall suspension feel....not sloppy, just less taut...more comfortable. Clearly a significant change, great improvement for a daily or general commuting.
* Steering felt a half step off (slower) than the aggressive stock setup in Comfort setting....also felt lighter.
* In Sport setting the understated "nervousness" feeling of the stock Comfort setting returned...sort of in the background.
* Steering tightened somewhat, and quickened.
* Reaction to road condition irregularities was still good...but slightly stiffer.
* Overall an improvement in responsiveness with a mild tradeoff on ride quality.
Extended driving impressions: mix of backroads, highway... mostly 50mph or higher, aggressive and mild driving mix
Note: as the speeds increased the car's suspension became noticeably more responsive in all settings, low speed initial impressions faded into an overall improvement in driving and handling, even Comfort setting became a mix of better ride quality and very good handling......but hints of turn-in roll remains, more on this later.
Test setup: Car was in Individual mode, only adjusted Engine, Steering and Suspension settings, individually.
A) Initial settings: Engine: +R, Steering: comfort, Suspension: comfort.
* Good ride quality, although it felt soft and exhibited roll at turn-in under hard cornering situations at elevated speeds. Good for general driving, great on the hwy.
B) Settings: same but suspension in sport setting
* Slightly stiffer ride, (similar to stock Comfort), cornering improved but still had a slight turn-in roll vs stock setting.
C) Steering and suspension in sport
* Sport steering seemed to help improve roll stiffness, grip increased
D) Settings: Engine +R, Steering: +R, Suspension: sport
* The +R steering change appeared to further reduce turn-in roll and the car felt notably more nimble, but it was a very viable and competent handling change.
E) Settings; all +R
* This setup provided a very capable aggressive setup for driving backroads at substantial speeds...a nice blend of performance, handling, and overall feel.
* Note: this setup is aggressive and compromised for highway driving under 75 mph.
Whether actually true or not, my seat of the pants impressions are that the DSC module provides an expanded use of the CTR modes for almost any street situation, including a sporty daily driver all the way to aggressive street handling....when used right out of the box on a stock CTR FL5.
I have found my preferred setup to be as follows: Hwy and general daily driving - Comfort Mode, performance street driving either Sport Mode or Individual Mode (Eng +R, Steering Sport, Suspension Sport), and for aggressive street driving either +R or Individual Mode (Eng +R, Steering +R, Suspension Sport).
I plan on tweaking these setups by adding a 22mm Whiteline rear sway bar to provide just a bit of additional turn-in roll control and overall cornering grip.
Enjoy your DSC!
J_D
J
Montreal
How does comfort suspension feel versus your old Integra Type S ?
lflouie
jeff
Knoxville, TN
Audi S4, Audi A4
Had lots of cars but never owned and Integra Type S. Drove one 2 yrs ago and thought it was okay...a little to refined for m tastes.
Evox787
Elvin
Amazing write-up! Thanks for the feedback. I’m leaning toward doing this, but I’ll fix my alignment and everything first, then go from there. It’s awesome that you have this option—I really like how responsive it feels. I don’t really notice the harness that everyone talks about. I rode with my wife in R+ mode, and she didn’t notice anything either—probably just our roads.
If I decide to add lowering springs, this seems like a great way to set it up to my liking. You’re the one who does the tuning, right? I think this could also help slow down shock wear a bit when using lowering springs.
lflouie
jeff
Knoxville, TN
Audi S4, Audi A4
Amazing write-up! Thanks for the feedback. I’m leaning toward doing this, but I’ll fix my alignment and everything first, then go from there. It’s awesome that you have this option—I really like how respons⁸ive it feels. I don’t really notice the harness that everyone talks about. I rode with my wife in R+ mode, and she didn’t notice anything either—probably just our roads.
Yes, you can tune it and DSC has tutorials. Also look at DSC SUSPENSION thread on Integra Type S site. At least one of the members has done the tuning for a car with springs and provides programming change suggestions.....a lot of tuning and diagnostic work already done. Also good background info on what the DSC actually does and how it works....quite a capable unit.
RODSCIVIC
Great write up! I am also a former RS Owner with DSC Module. I also had Mountune Lowering Springs and also one of the first to receive the DSC when it first came out. If anything I think the DSC made the RS livable with the suspension from factory. It worked for the most part but you're right, the handling suffered since it was an out the box solution with no improvement to tunes at the time.
The CTR to me is comfortable from Factory compared to the RS, however, Sport and +R are pretty much useless. I just ordered the DSC after reading reviews here. I was going to opt for the ITS Module but didnt really want to ruin the CTR experience. Hopefully everything works out.
Pic of said RS:
11th Gen Honda Civic DSC suspension controller feedback/experience on a stock CTR FL5 IMG_0187
lflouie
jeff
Knoxville, TN
Audi S4, Audi A4
Pic of said RS:
Here's my 2016 RS on the Dragon...one of my favorite sporty weekend backroad cars.
I've spoken with CTR owners that have used the DE5 suspension module and ITS owners. The common comments from CTR owners that use or used the DE5 module is that it is a significant positive change on the overall drivability ....but it can be "floaty" in low speed Comfort setting driving (around town), but Sport setting is more usable. The DSC (factory programming) in the CTR is not floaty but has a softer turn-in at lower speeds (under 30 mph) and my impressions are that while oem module is adaptive, the DSC uses a far wider range of damping than the oem. This results in a given suspension setting having a far wider range, so a Comfort setting can actually work at higher speeds where the oem range couldn't. With oem MODULES this required stepping up to a higher setting which then compromised the lower speed ride quality.
After a 200 mi drive in the mtns with the DSC I found that I never needed to use the +R suspension setting for high speed cornering and did most of the high speed cornering in Sport. On the really tight corners while braking from higher speeds the Comfort setting provided exceptional grip with enough weight transfer to make for a confidence inspiring handling...especially on bumpy corners/roads.
The DSC also elevates higher speed transition braking by resisting brake dive through electronic suspension damping (front stiffening) that provides great confidence.
If you like aggressive cornering and drive on a mix of road surface conditions you should find the DSC as a worthwhile upgrade...I have!
11th Gen Honda Civic DSC suspension controller feedback/experience on a stock CTR FL5 20170329_162441
Evox787
Elvin
That’s another great car! The RS is really hard to come by used, and when the opportunity came, I jumped into the FL5. My wife said if I didn’t get a new car, I was going to be in trouble—so I avoided the issue 😂. I love the gray and the blue RS!
Nice review.
Prior to the DSC I had the ITS module which I installed a few weeks after I purchased my FL5 about a year ago, ITS was "better" as far is it wasn't as teeth rattling.
I installed the DSC about a month ago, and even though I did not drive much on it, I can concur with OP review.
I noticed that the DSC automagically adjusts and firms up in comfort mode.
lflouie
jeff
Knoxville, TN
Audi S4, Audi A4
I have very little experience in suspension modifications. I am currently researching rear sway bars.
My top contender is the RV6 rear sway bar
https://rv6-p.com/products/rv6-17-civic-type-r-2-0t-fk8-rear-sway-bar-with-endlink
I am curious why you plan to go with Whiteline?
https://whitelineperformance.com/us...11th-gen-fc-fk-fk8-fe-fl-fl5-9986-bhr97z.html
Swaybars are basically acting as a cornering spring...they only apply force when the car is not going straight. They are intended to act as a " final tweak" balancing out wheel spring rates and load transfer during turning. They will affect turn-in feel bc they increase the rate of load transfer from front to rear, with the majority of the transfer going to the opposite front wheel. This " preloads" the outside front wheel as you turn into the corner...making the car more responsive to steering wheel inputs and increasing outside front tire grip ( reduces push).
Choosing a swaybar is all about balancing the car based on the current suspension, primary use and application ( road racing, HPDE, autocross, spirited street, daily driver, etc.). It is also dependent on driving style, personal preferences and willingness to trade-off ride quality for cornering grip (cornering speed).
Before selecting a swaybar you'll need to determine your goals and personal preferences, what youre trying to "fix," as well as what you don't want.( level of ride harshness)
First of all, today's cars, especially the CTR, have very capable electronic adaptive suspensions with capabilities and algorythms that make them far more adaptive and sophisticated than ever. For example they can stiffen one or more shock's damping to aid cornering for different cornering speeds, braking levels and G- forces....something that traditional mechanical setups can not do.
With that said, aftermarket spring choices, wheel offsets, tire choice (and pressures), alignments, as well as swaybars determine the overall "suspension characteristics" and overall nature of the car.
My experience with well setup oem systems, the development work and the engineers emphasis are the baseline that a driver needs to understand and analyze for their particular intended use. What works for me may not work for you...or atleast fail to met your expectations. If lap times on a road racing track is your goal, then setup the car accordingly, if not then define the use and goals and set out to meet a set of objectives.
Well after that philosopical guidance let's get back to why a Whiteline vs RV6. If I was setting up a track car the RV6 would be a contender bc it has one of the stiffest settings (rating) of the commonly available bars and has a wide range of setting/choice options....perfect for dialing in the car for various tracks and track conditions, and when matched to the other changes that would be made to a "track car" suspension package. Remember all of the parts of a suspension are part of a system...change one and the others may or may not be ideal.
The Whiteline is at the opposite end of the spectrum with modest stiffness increases and adjustments. Bc the CTR factory oem suspension (and module tuning) are already very responsive and set to the stiffer side of ride quality and with virtually no push, adding any swaybar stiffness for non-race purposes should be done to address a specific issue or need. Bigger(stiffer) is not necessarily better.
In my case, I'm considering a Whiteline 22mm rear bar to aid in turn-in feel and low speed steering response for driving on tight hairpin turns on mountain roads. It is only ~ 15 to 30% stiffer than stock so it shouldn't compromise the overall goodnesd of the DSC tuning.
I find that many enthusiasts select swaybars that are too thick (racing oriented) and overly and unnecessarily stiff. They will tighten up steering responsiveness at any speed, but introduce other trade-offs.
If this is your first foray into suspension tuning the good news is the CTR needs very little help for performance oriented enthusiasts or for limited track use. In my case I feel the DSC dials in a better balance btwn race use and aggressive street by tuning the suspension via the module, and I'm only considering a Whiteline for my specific mountain carving needs at low speeds....otherwise I like the DSC as a plug and play unit and possibly the Whiteline bar as a tweak on my otherwise stock CTR.
If you are looking for an improved overall suspension upgrade and ride quality I would recommend an off-the-shelf DSC. Remember that a rear swaybar including adjustable end links will cost around $500 to $600 and requires installation. A DSC is a 15 min install in the driveway, and will greatly enhance the overall suspension even for competition, Something to consider, especially if you are going to routinely daily drive your CTR, it costs $999, far less than doing multiple suspension upgrades and experimenting. When you sell your CTR, just replace with the oem module and you'll get most of your DSC investment back.
Since you already have the DSC. if you want more enhancement try contacting them for a possible programming tweak to address any short coming.
Which ever direction you choose, enjoy your CTR and your DSC for what they are......basically 90% of a GT3 for 20% of the cost.
FWIW while on the topic of sway bars- but first a disclaimer: DSC is local to me and I took my car there to use as a tuning benchmark for the baseline tune on a lowered suspension you all would get if you ordered a DSC now (although they've probably revised it since, honestly...).
In any case, while there I had a great chat with Tom, not sure of his role but as far as I'm concerned he's the product manager for the DSC controller. He is an elite expert on suspension, and that's another component you get when you buy a DSC- it comes with a baseline tune that is dialed in by a team of true experts. But even better than that- they can assist with helping you tune the unit to your individual preferences. He actually was telling me about how he had just worked with an FL5 owner in developing a custom DSC tune that essentially equated to a "virtual sway bar" by tweaking the dynamic damping on the rear only to account for conditions that would benefit from increased oversteer.
If that's something any of you is interested in, I suggest reaching out to Tom.
There's also even a use case for folks going to non-adjustable coilovers, utilizing the DSC controller as a more effective ADS delete mechanism than the "plug in" units you'd get from Ohlins or similar.
Very trick piece of kit. Even for a "refined" DE5.🧐🧐🧐
derbo904
Keeper of Blinky lights
Bay Area, CA
23 FL5
@optronix There's also even a use case for folks going to non-adjustable coilovers, utilizing the DSC controller as a more effective ADS delete mechanism than the "plug in" units you'd get from Ohlins or similar.
How would this work?
Maya@DSC
Maya
Jessup, Maryland
www.dscsport.com
Civic
