πŸš€ TRUSTALIGN - Time Attack FL5 Build Journal
tezzasaurusrex
Terence
This thread will serve as the build journal for my FL5. As you will see as you read through the thread, you will find that the vehicle has evolved slowly over time, from a mildly modified street car to something resembling a clubsport style road and race car.
Currently, the modifications are as listed (*updated* July 2026)
Engine:
Stock
Motul 0W30 8100 Eco-Clean for street duties
Motul 5W30 8100 Power for ethanol/track use
Turbo/intake:
Custom Intake System
MHI stage 2
Fueling:
Hondata Canflex
Hondata 1530cc injectors
Full Race HPFP
AEM drop in LPFP
Cooling:
OEM radiator
HKS intercooler with HKS piping kit
Transmission:
Stock Gears
Spoon Mechanical LSD
Motul Gear FF Type 2
Brakes:
Front: Alcon Car89 TA6 w/ 355x32mm Alcon rotors and Endless ME22 pads
Rear: Stock caliper with brass bushings, Paragon 2 PC discs and Project Mu pads
Motul RBF700 Fluid
Exhaust:
Invidia Catless downpipe with hard lagging
PRL 3" Front pipe with hard lagging
Custom 3" titanium single exit system
Suspension:
AST 5300 Coilovers
Hardrace FK8 Front Camber Ball Joints
Hardrace hardened rubber Front LCA bushing (rear position)
Spoon Zero Bump Steer Ball Joints
Eibach Rear Upper Camber Arm
Hardrace rear knuckle Spherical (B arm)
Eibach rear lower A arm
Custom tubular rear lower B arm
OEM front sway bar with adjustable AST end links
Custom RSR style rear sway bar system with adjustable Eibach end links
Alignment:
Camber FR -4Β°, RR -3Β° (was -2.7Β°, -2Β°)
Combined Toe FR 0mm, RR +3mm (was 0, +2mm)
Body/Aero:
Rear Wiper Deleted
Custom Side Mirrors
Custom Carbon/ribbed core front splitter with tunnels and end plates, completely curved underside.
Voltex Type 2 rear wing w/ gurney flap and custom 6mm carbon fibre uprights
Front brake ducts blocked off
Interior:
TRUSTALIGN Schedule J Half Cage
Rear seats removed
Recaro RS-GS FIA Black
Schroth 6 pt harness
My fastest lap times currently at various circuits are:
Sydney Motorsport Park GP 1:38.8 (WTAC 2026)
Winton Motor Raceway Full Circuit 1:34.88 (Natsoft) (Note: Stock springs, FK8 Ball Joint, Aus Time Attack 2023)
Luddenham Raceway 51.9 (LogR, 2023)
I will keep this thread updated as best as possible with modifications and speed secrets that I discover along the way. The aim is to knock those pesky BMW's off the top of the time sheets.
11th Gen Honda Civic πŸš€ TRUSTALIGN - Time Attack FL5 Build Journal 20260714_161000
11th Gen Honda Civic πŸš€ TRUSTALIGN - Time Attack FL5 Build Journal FB_IMG_1778384306444
11th Gen Honda Civic πŸš€ TRUSTALIGN - Time Attack FL5 Build Journal FB_IMG_1759441958644
11th Gen Honda Civic πŸš€ TRUSTALIGN - Time Attack FL5 Build Journal FB_IMG_1778384372916
11th Gen Honda Civic πŸš€ TRUSTALIGN - Time Attack FL5 Build Journal Screenshot_20260928_102414_Instagram
CTR
strixauto.com
2023 Civic Type R, 2020 GX460
I'm excited to follow your build. You seem super knowledgeable about setting up a track car that's still practical. Thanks for sharing so much already!
tezzasaurusrex
tezzasaurusrex
Terence
Thanks for your kind words. Gone are the days where I would turn a car into something so extreme that I can't enjoy driving normally. I want the speed, and I want the practicality. ?
Im curious about the rear spring shim. I haven’t seen a reverse rake before with Spoon springs.
I would say every FL5 fitted with Spoon springs are exhibiting around an 8-10mm reverse rake (rear being lower) if it were to be measured on a perfectly level surface. I'm still currently working with a fabrication shop to make them sit perfect in the body recess, as the surface is not perfectly flat.
11th Gen Honda Civic πŸš€ TRUSTALIGN - Time Attack FL5 Build Journal 20230627_174558
11th Gen Honda Civic πŸš€ TRUSTALIGN - Time Attack FL5 Build Journal 20230627_174451
keller
Somewhere south
2019 fc3, 2021 fk8
Have you calibrated your ride height sensors after lowering the car? Most FK8 people didn't bother doing it, but our suspension is not that overdampened from factory.
BTW, can you post onboard videos of your track outings? I could bet I'm not the only one that enjoy watching those =)
tezzasaurusrex
tezzasaurusrex
Terence
I have not, but it would be a good thing to do for sure!
Here's some videos on my youtube channel :)
A good one making an NA K series sing
UJX
Missouri
2023 Honda Civic Type-R #2479
Do you have a rear camber kit installed? I have a set of Spoon springs but haven't installed them yet and was wondering what kind of camber the rears would be at after the drop. Ideally I'd like to have both front and rear around the same as I don't track the car as of yet.
OsosikMedia
Nick
sik! Australia has some nice tracks!!!
tezzasaurusrex
tezzasaurusrex
Terence
Running stock arms. Rear camber went from -1.3Β° to around -2Β° after installing the Spoon springs (depends on fuel load).
If you pull the front strut pins out you'll be at around -1.8Β° which should bring front to rear reasonably close. However I always prefer to run more front camber so I'd recommend getting the camber adjustable front ball joint regardless.
keller
Somewhere south
2019 fc3, 2021 fk8
Have you tracked your car with the stock wheels? Have you noticed any difference in handling when you increased both track widths by 30mm due to the different wheel offsets?
tezzasaurusrex
tezzasaurusrex
Terence
I haven't - as I intend on keeping the stock tyres in ideal condition for normal street driving. But I am running 20mm spacers under the stock wheels at the moment on the road and I can't say there is a huge difference in handling between ET60 and effectively ET40. Perhaps a tiny bit extra torque steer but nothing too significant.
albi
Dallas, TX
Body: Rear Wiper Deleted
What kit did you use for the rear wiper delete? I did not notice it in the pics or vids but may have overlooked it.
