🚀 TRUSTALIGN - Time Attack FL5 Build Journal
jtlctr
Jake
3rd place when I looked! Nice!
joshinthecity
Josh
Sydney Australia
2025 CTR. Championship White.
Check out post #71 in this thread where I detail some of it. There are a lot of gaps and inefficiencies in the OEM set up. The main killer is the absolutely huge gap between the side of the radiator and the CFRFP support panel, it's around 20mm either side, which if left uncovered is simply allowing large volume of airflow to do nothing but increase under hood pressures further reducing air volume going through the heat exchangers.
There's an opportunity and an addressable market if you happened to be interested in offering a "fix" for this as a product.
*puts hand in the air*
Josh.
tezzasaurusrex
tezzasaurusrex
Terence
2026 WTAC done and dusted
P5
With a new PB, 1:38.81 - SMSP GP Layout
Fought our asses off to get into the top 5 shootout but a little rain and a premature call to cancel further proceedings robbed us of the chance to show the world what this car can really do on a clear track in optimal conditions.
The competition was tougher this year, with far more BMW entries, this competition is in danger of becoming BMW cup. 😅
Enjoy the lap:
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal IMG_20260905_184941_730
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal Screenshot_20260907_124727_YouTu
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal Screenshot_20260906_214509_Instagram
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal FB_IMG_1788605574438
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal Trustalign WTAC 2026 4
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal Trustalign WTAC 2026 36
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal Trustalign WTAC 2026 2
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal Trustalign WTAC 2026 8
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal IMG_20260909_172231_190
tezzasaurusrex
tezzasaurusrex
Terence
Josh.
I disagree, time and time again people have proved they are more interested in buying shiny purple silicone upside down hoses or JDM thermostats than actually paying my shop to rectify their cooling issues.
joshinthecity
Josh
Sydney Australia
Fair enough. By average, I suspect you're probably right. *sigh*. A sad state of affairs.
There's nothing shiny on my car at all though, and I was on the track at SMSP just last night.
I guess I'm the minority.
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal jj
tezzasaurusrex
tezzasaurusrex
Terence
All you have to do is make a booking ;)
tezzasaurusrex
tezzasaurusrex
Terence
If the cooling mods you've done are on the table then I would also be down to have this done, just got to drive up from Canberra 😅
Everything's on the table bud you simply need to ask 😊
CG13
Houston
2024 FL5 Civic Type R
Great thread.
I’ve been dealing with two main challenges with the FL5 on track, cooling and tire wear.
For cooling I’ve done:
PWR WOT radiator + transmission cooler
PWR intercooler
HEL oil cooler
Downpipe with heat shield, turbo heat shield
I am waiting on Js Racing vented hood
For tire wear I’ve done:
EVS ball joints with -3 deg camber on the fronts
I’ve tried: Michelin PS4S, Michelin Cup 2, Pirelli Trofeo R, Nankang CR-S
Acura Integra Type S suspension module
RV6 rear sway bar
I saw in earlier posts you were running a PWR radiator, but your most recent post mentioned running on the OEM one. What made you go back to OEM?
Can you describe the impact of moving to the Spoon LSD? I’ve been considering a clutch type LSD but haven’t decided if it’s worth the additional maintenance. Does Spoon provide any recommendations on fluid change intervals or rebuilds?
tezzasaurusrex
tezzasaurusrex
Terence
That's right, on Australian 98 octane (equivalent to US 93), the car is more susceptible to overheating. For the type of racing that we take part in, which is time attack events, we are able to run E85 fuel, which solves about 50-60% of the cooling issues. And we don't need cooling capacity since we're doing single lap full noise runs, and cool downs in between, rather than lap after lap of mode push, because the tyre window is narrow. So the move back to the OEM radiator was made to pull weight off the nose of the car, reducing the polar moment to help it change direction. Like I have beaten to death, manage the air flow, and you won't need all the extra cooling mods, adding weight, parasitic oil pressure losses and additional points of failure.
So far we have not experienced any additional maintenance for the Spoon LSD. Stick to metal plate clutches, rather than carbon plate clutches, and you won't have excessively high oil contamination and the need to change oil so often. We change oil in these transmissions every 2-3 track events depending on track and temperature/time of the year, whether it is completely stock or with clutch type LSD together with engine oil.
tezzasaurusrex
tezzasaurusrex
Terence
More shots and videos from WTAC 2026
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal IMG_4892
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal IMG_4825
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal Screenshot_20260928_102414_Instagram
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20260904_WTAC_0002
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 260903_WTAC26_Track_0003
CbFk8RGC2
Gabriel
2018 Civic Type R
A note on the Spoon spring spacers, I've now installed several sets of new release Spoon springs (now have thicker and higher quality black spring insulator on them) and have discovered they no longer sit low in the rear.
So for anyone who have the new release springs, you do not need the spacer I developed to raise the rear end.
If your springs have blue insulators on the front, then you have the original batch which from my observations all sit low in the rear.
If you have any questions feel free to respond here or send me a PM.
Thanks all
So if I have the blue insulators in the rear and black insulators up front I won’t get the rear rake? Thanks in advance.
Thanks all
So if I have black insulators up front and blue insulators in the rear I won’t get the rear rake?
Thanks in advance,
Thanks all
So if my front springs have black insulators and the rears have blue insulators I won’t get the rear rake? Thanks in advance.
tezzasaurusrex
tezzasaurusrex
Terence
If you have blue insulators, you have the old batch.
CbFk8RGC2
Gabriel
2018 Civic Type R
Thanks for the clarification, how can I fix this ? What do I need to purchase?
tezzasaurusrex
tezzasaurusrex
Terence
You need the spring spacers that I made ref post #27 in this thread. I no longer produce them since demand has dropped but you might find them floating around out there.
