🔴💊 Engine Oil Red Pill Thread: Only Post If You Have UOA - Official Honda Civic Type R K20C1 Engine Oil Analysis
cryptolime
Wilmington, NC
The 15400-PLM-A02 was manufactured under contract by Honeywell/Fram (the blue-can version which was cut open and compared to Fram PH7317 Extra Guard).
Fram’s parent company (First Brands Group) did file Chapter 11 bankruptcy, and Fram filters are no longer available, thoush
Which is why I did not compare it as I assume that it is no longer available like other Fram made filters.
Yet it seems that Honda still has a large stock of the A02
In March 2026 First Brands agreed to sell the Fram brand name, trademarks, patents, engineering know-how, and related intellectual property assets for 12 brands to Premium Guard Inc. (PGI), but it seems that the original Fram factories are permanently closed and being liquidated. PGI will probably sell their own filters under the Fram brand name
i bought one yesterday
zumbooruk
Ventura CA
I suspected that the reason Royal Purple was both a very good filter, and is no longer available meant that it was a rebranded Fram.
I was close. Royal Purple was made by Champion Labs, which was another company under the same parent company of Fram.
Mobil 1, Royal Purple, Amsoil, and K&N oil filters were all primarily manufactured by Champion Laboratories (Champ Labs) under the First Brands Group umbrella.
Champion Labs produced these to each brand's specifications using similar synthetic or synthetic-blend media platforms. This is why many of them share comparable internal construction, anti-drainback valves, and performance characteristics in cut-open comparisons and independent testing.
The Albion, Illinois plant closed abruptly in February 2026 following the First Brands bankruptcy.
apparently Mobil 1 is the only one still widely available because of larger inventory and distribution warehouses (as it is one of the most purchased brands)
bottom line, seems that the current choices are:
Mobil 1 was made by Champion Labs, but still seems to be available
Purolator and Wix are both made by MANN+HUMMEL
Bosch
zumbooruk
Ventura CA
One last observation per my latest research
Apparently the "regular" Wix and Purolator are better at ultra fine particle filtering (turbocharger protection), with Purolator ONE slightly better than regular Wix.
Purolator ONE
real world is model-specific up to 99% at 17–20 µm
mfg claim: 99% at 20 µm
Regular Wix (non-XP)
~95% (historical beta ratios)
mfg claim: 95–99% at 20–23 µm
cryptolime
Wilmington, NC
Purolator ONE
do you have any more info on how fine particles can damage turbos? i'm guessing the GDI soot isn't great for it
hard to find info on the most efficient oil filters.
what's the efficiency of the Honda PLMA02 filter?
johnloov
johnloov
John
This is great information especially for those running 5k-10k miles between oil changes. All this data and conversations are coming to a head, which is replacing your engine oil a lot more frequently at 2000 3000 miles and transmission fluid eliminates particles floating through the system and the best way I can describe it is like imagine putting sand into oil and rubbing your fingers together. No matter what oil you choose the frequency of changing it matters more. I may even try at some point Costco motor oil at half the price and just change it often.
zumbooruk
Ventura CA
I did not research damage to turbos, I stumbled upon it while searching for replacements to First Brands oil filters. several mentions that the "ultra fine particles" act like abrasives, amplified since turbos spin extremely fast (if I recall correctly, one mention said 100K to 300K RPM)
It is indeed not easy to find reliable info for oil filters. most are "manufacturer's claims" or "manufacturer's testing"
yet the only independent test I found showed that Puroloator Boss was way under performing the claims 99% vs 62% if I recall correctly.
Honda A02 was made by Fram, tear down / cut up showed it was identical to the cheapest Fram model.
this is what I found:
FRAM Extra Guard ( representative model PH7317):
Filtering efficiency per ISO 4548-12: 95% for particles greater than 20 microns.
Effective micron rating at 99% capture: Not published by the manufacturer.
Honda 15400-PLM-A02 (OEM filter manufactured by Fram/Honeywell):
Filtering efficiency per ISO 4548-12: No official manufacturer-published value located.
Effective micron rating at 99% capture: Not published. Third-party parts databases report 95% efficiency at 40 microns and 50% efficiency at approximately 23 microns.
BLU RRR
Jeff
South Central PA
first oil change at 1000 miles and second at 3200. Copper and Iron significantly lower, Aluminum up but was double the miles. Horizon/Amsoil uses a different test for fuel dilution than blackstone.
My car runs short trips during the week and gets exercise on the weekends. Interesting this is significantly less wear metal than my 24 subaru crosstrek at approx the same OCI.
