2023 FL5 Civic type R accessory installation
Loudogdude
Lou
NJ
23' Honda Civic Type R
Hey y'all if anyone interested i'm looking to part with the foot/under seat light set & the trunk tailgate light install kit hmu
mccoma4
michael
Jacksonville, fl
2023 fl5,2021 audi rs6 avant,2022 ford f250 shelby
I'm going to stop by the dealership tomorrow and see if the poor guy in Parts can help me with a wiring diagram for the door harness. Clearly I've tapped into the wrong wire in each one, but I followed the instructions, which tells me the instructions are RHD-specific and LHD models are slightly different.
I lucked out tonight as I set out to do some exploratory surgery--I put the windows down with the door open and just happened to notice the pattern on the driver's side.
I'll admit I'm slightly relieved to think I'm close to getting these working, just need to know which of the ~20 wires I should be using.
have you found which set of wires make these run properly? ive ran into a wall so far. the idea i had makes them too dim
RUNN1N
Care to share a picture of your results and a breakdown of how you got there?
I'm not an electrician, but I assumed these weren't dimmable and therefore wouldn't function with insufficient power.
mccoma4
michael
Jacksonville, fl
I have not found an answer as of yet. but i have learned that the integras come standard with the plug in. ;( so im going to dig in and see if i can compare the two
RUNN1N
Yeah the Integra has a plug inside the door for the pattern projector.
Someone previously circulated instructions from a dealership in Germany for installing the Type R pattern projectors. These may be useful for wiring USDM Type R's as both markets are LHD. The UK/Japan instructions should not be followed as they are RHD-specific. Did you follow any instructions when wiring yours?
Pictures of your dim projectors and a breakdown of how you wired yours would be helpful.
mccoma4
michael
Jacksonville, fl
currently the only test run i had was tying the red on the the hot of the accent light on the door panel. the green to the green wire on the 37 pin connector. and the black wire to the body ground of the door. so that was my first failed attempt
arcticdc5
William
Back from the dead! Any links for instructions on the footwell lighting, center console lights and door panel pocket/door handle illumination sets?
I believe @JDM_DOHC_SiR is your guy on this.
arcticdc5
William
@JDM_DOHC_SiR - could you point me in the direction for the JDM/Eurpoean drink cup/center console, footwell & door panel handle & door pocket illumination instructions? Just ordered from Blackhawk Japan and wanted to see how the installation goes.
Much appreciated!
JDM_DOHC_SiR
Uncle Dave
Chula Vista
I’ll see if I can get some info up here in the next couple of days:thumbsup:
Won’t be back home until the end of the week and I have the info you need at home…
RUNN1N
Much appreciated!
I'm not locating the footwell lighting instructions, but here are the cupholder/center console, and door instructions--good luck!
arcticdc5
William
Wow - thank you so much!!! 2 out of 3 ain't too shabby at all! Looks as if all these illumination sets should be installed at the same time as dash dissassembly is needed!
Again - Thank you so much!
RUNN1N
Installing everything at once is definitely the way to go--I just made sure I had a long weekend where I didn't need the car, and knocked each one out as I found time.
This would also be a good time to add the Mikstore rear vent and USB kit. You'll already have everything apart, and that upgrade adds ~$400 and ~30min to the job. Well worth it, in my opinion!
