2024 Championship White (FL5) - Michelin Pilot Sport 4AS (265/35/19)- H&R Springs- H&R Spacers 20(F)- 25(R)
FL5HondaGuy
Boston
2024 Championship White FL5
11th Gen Honda Civic 2024 Championship White (FL5) - Michelin Pilot Sport 4AS (265/35/19)- H&R Springs- H&R Spacers 20(F)- 25(R) FL5 Side Profile
11th Gen Honda Civic 2024 Championship White (FL5) - Michelin Pilot Sport 4AS (265/35/19)- H&R Springs- H&R Spacers 20(F)- 25(R) Front Poke
11th Gen Honda Civic 2024 Championship White (FL5) - Michelin Pilot Sport 4AS (265/35/19)- H&R Springs- H&R Spacers 20(F)- 25(R) Poke Side
FL5HondaGuy
FL5HondaGuy
Boston
Just got my set up done and wanted to share some snaps. It just got done raining/snowing . Car drives just like stock with a little more sidewall (lol). H&R's are incredibly sublime but just the right amount of stiffness to know something is different. No cringe factor. No puckered balloon knot going over bumps. Car looks absolutely fantastic. Pictures don't do it justice. IMO the perfect OEM + look. Just look at her. Cheers Everyone and Happy Holidays !!
Robo7
Looks perfect! I'm glad you posted some pictures. I've been waffling back and forth on what to do. My H&R springs and Bonoss spacers just arrived. I wasn't sure about adding larger tires, but the extra sidewall looks so much better than stock to me. Excited to get this setup myself!
Alexx
Alex
2025 Civic Type R, 2022 BMW M4
Looks great! What tire pressure are you running on those tires?
FL5HondaGuy
FL5HondaGuy
Boston
Just picked up The PRL High Volume Intake System. Grabbed some red overlay inserts for the back of the front seats to make the TYPE R logo red. Cant wait for the warm weather.
FL5HondaGuy
FL5HondaGuy
Boston
New Aeroflow Dynamics Champ White Spoiler.
11th Gen Honda Civic 2024 Championship White (FL5) - Michelin Pilot Sport 4AS (265/35/19)- H&R Springs- H&R Spacers 20(F)- 25(R) side 1
11th Gen Honda Civic 2024 Championship White (FL5) - Michelin Pilot Sport 4AS (265/35/19)- H&R Springs- H&R Spacers 20(F)- 25(R) front 1
11th Gen Honda Civic 2024 Championship White (FL5) - Michelin Pilot Sport 4AS (265/35/19)- H&R Springs- H&R Spacers 20(F)- 25(R) Spoiler back 1
Evox787
Elvin
How much is the difference on drop from OEM on those H&R springs? And is not drop more on the back like on the spoon springs? Can you post link on the spoiler and wonder if it was straight forward install and if it comes on gloss black? Thanks for sharing!
Robo7
Found a video by LHT Performance on YouTube where he installed H&R Springs on his FL5.
Top numbers were with stock springs, bottom was with H&R Springs immediately after install so they hadn't settled yet. Still, looks like an even 1/2" drop which slightly different than advertised (H&R specs say the front is a bigger drop than rear, but in this example that wasn't the case, perhaps the front will settle lower than the rear?).
If anyone has the Eibach Pro-Kit measurements on an otherwise stock setup I would love to know.
FL5HondaGuy
FL5HondaGuy
Boston
H&R's
- Approx. Front Lowering: .75 inch / Approx. Rear Lowering: .60 inch
No bump stop cutting required
There is no reverse rake like the earlier batch from SPOON.
I do believe the more recent runs from SPOON do not experience the " body in the trunk" look but you might want to confirm with those that have them.
Spoiler:
Straight forward install with a T30 screwdriver . 3 bolts on each side.
Its a little lighter than stock (no I am not weighing it)
It sits lower than stock and you can see it when you look out the rear view but it doesn't fully block your view (e.g. like my older 2006 STI spoiler did).
You can def get it in black from the website.
https://www.aeroflowdynamics.com/pr...r-rear-spoiler-v1?_pos=2&_fid=357e23cab&_ss=c
Evox787
Elvin
H&R's
Spoiler:
Thanks I was looking at the H&R because I want to lower mine but don’t want to lower it a lot due to the fact that my driveway is a little steep and now the little lip that comes off de bumper scratches a little sometimes. I wasn’t expecting to weigh the spoiler is irrelevant to lose probably 2 oz over stock 🤣 but thanks for the insight, what you say about the sitting lower it doesn’t have the same curve as the stock one? It might show on my rear view mirror a little bit? On my Evo X that was one of the issues that I hate 🤣!
FL5HondaGuy
FL5HondaGuy
Boston
The spoiler is a different design. The stock spoiler has an upward curve which is the main reason you cant see it when looking out the rear window. This newer color matched design is pitched forward and angled lower . You will def see it in the top of the rear window but it doesn't block the entire window like the STI or EVO does. Cheers
FL5HondaGuy
FL5HondaGuy
Boston
11th Gen Honda Civic 2024 Championship White (FL5) - Michelin Pilot Sport 4AS (265/35/19)- H&R Springs- H&R Spacers 20(F)- 25(R) rear set
gotham
Chad
West Virginia
2025 CW Type R
Do you think a 25mm spacer instead of 20 on the front would rub on this setup?
Did you pull the pins?
thanks!!
Robo7
Man I need some Advans. That looks 🔥
