2024 Season: Brake Hardware Recap
**UPDATE**
Added another 70 Laps to this set up.
C1X Pads -- now at 252 Laps across 10 Track Days and multiple new PBs
Girodisc Rotors -- now at 602 Laps across 23 Track Days
What are you using for the rear?
yeah definitely consideration for the next set, despite the price but I would pay if the pads have great street maners but also excellent on track.
also J1avs 250 laps is probably a good 600 of my laps in terms of wear so these could last a LONG time
@J1Avs can you comment on the CSG pads you’ve used so far whether they squeal a lot in street driving? I’m looking into the Girodisc rotors front and rear but would only try out these CSG pads if they don’t squeal too much. Trying to appease the wife. Thanks.
Yeah definitely going to get these when I need new pads.
J1Avs
J1Avs
James
Seattle, WA
www.instagram.com
Cool. Looking on the website, why not just go with the CP? On their website it shows it has the most pad life.
https://www.counterspacegarage.com/csg-spec-brake-pads
The rear pads are all priced similarly. Wondering what the differences are
The CP is technically a Street Pad, but it can handle track use very well. It definitely has the most pad life on the street, because it operates the best at those lower temps. But, when comparing on track to on track, it does not have the same life as the C1X.
The rears are just slightly different in applications. CP = Street (and some Track duty), CE1 = Euduro (Think low Mu, low bite, long life), and C11 (Rear only compound, Digressive, but higher bite than CE1). I am going to be trying the C11 in the rear next, as I'm looking for a little bit more bite in the rear to pull some of the load off the front and reduce the amount of dive and load on the front tires before turn in.
J1Avs
J1Avs
James
Seattle, WA
www.instagram.com
CPs are dead quiet. That's your hybrid option. The C1X is also super quiet. Everyone once in a while I hear the tiniest squeal, but it's not regular and certainly not obnoxious. Nothing like what I experienced with PMU Racing999's or Carbotechs on other vehicles, where I was embarrassed at every light
I know you had said the GD rotors dissipate heat better than stock. Is this something you had measured or just going back the physical construct of the rotors?
I’m just asking before I order them…
J1Avs
J1Avs
James
Seattle, WA
www.instagram.com
Didn't measure -- just going back to construction and design. Pad life + Lack of Brownbos + Lack of Overheated Pads also demonstrates the effectiveness of the setup.
Do you know of the difference between the C12 and the C1XB?
I was just scrolling through and couldn't really find any info on it
J1Avs
J1Avs
James
Seattle, WA
www.instagram.com
C12 is a legit track only compound. Not recommended for street use at all — like don’t drive to and from the track on it. It will work, but wear is hyper accelerated outside of optimal temps. If your trailer, then go for it.
Zero7
Avtar
UK
FK8
@J1Avs - did your friend not do cool down laps and hence the slight discolouration of the Brembo lettering? If so do you think shims might have prevented that?
