AEM dryflow filter for PRL HVI intake
timestamped
DC
ā€˜24 boost blue FL5, ā€˜15 tuxedo black FoST3
Disclaimer: It should go without saying, but please do your own research before deciding on a different filter, just as you should before deciding on an aftermarket intake itself. I have personally run AEM filters for 10 years, no other non-OEM brands, but I have no affiliation and provide no guarantees.
Hey guys, sharing this AEM dryflow filter I just test-fitted with the PRL HVI:
21-2093DK
11th Gen Honda Civic AEM dryflow filter for PRL HVI intake IMG_9432
11th Gen Honda Civic AEM dryflow filter for PRL HVI intake IMG_9411
The PRL filter specs:
11th Gen Honda Civic AEM dryflow filter for PRL HVI intake IMG_9412
PRL on the left, AEM on the right:
11th Gen Honda Civic AEM dryflow filter for PRL HVI intake IMG_9449
Because the AEM is half inch shorter, it seems like it can maybe be pulled without removing the entire airbox which would be nice. Edit: nope it can’t :(
Haven’t installed yet, just mounted to the velocity stack, put inside the box and covered the ECU-side lid to check clearances.
While the PRL filter has to be stretched a bit onto the velocity stack, the AEM goes on loose and then snugs up once the clamp is tightened. The AEM filter has a nice double ridge the exact width of the clamp that holds it in place on the filter while tightening.
Cheers!
Edit: Adding another option from aFe POWER Takeda, found by @jtlctr, the AFE-TF-9007D appears closer in dimensions to the PRL
https://afepower.com/afe-power-tf-9...roU-zw4JuU2s-ugCWdPlAf2ifFosE30gSoDox9d6w4Ik6
11th Gen Honda Civic AEM dryflow filter for PRL HVI intake IMG_0437
The aFe PRO Dry S air filter used by the Takeda performance air intake system uses a 3-layer synthetic media that requires no oils. This filter is 99.2% efficient filtering out all of the most harmful air contaminants while allowing maximum flow. This filter requires no oils and cleans with soap and water for maximum convenience.
Filter Dimesions are 5.5" flange, 4.5" height and 7" base.
And one more option:
11th Gen Honda Civic AEM dryflow filter for PRL HVI intake IMG_1078
https://ramairusa.com/proram-medium...air-filter/?setCurrencyId=2&sku=PR-CC-194-150
CTR
strixauto.com
2023 Civic Type R, 2020 GX460
Nice! Thanks for sharing.
Does the filter webbing look to be about the same depth? How about the number of pleats? That half inch might not seem like that much but it could add up to a decent amount of surface area reduction.
timestamped
timestamped
DC
Good questions, I have no doubt the PRL has greater surface area, but even if they were identical dimensions an oiled filter will have slightly better flow / slightly worse filtration than a dry filter.
But for fun, I did some quick and dirty cone math. Not accounting for pleat number and depth, the lateral surface areas are roughly:
AEM filter: 80.2836 sq inches
PRL filter: 81.96 sq inches
Regarding the pleats, the AEM has 51 pleats with about 9/16ā€ depth, while the PRL has 70 pleats of about 7/16ā€ depth.
Multiplying the pleat number by 2 (in and out) and depth, you get the following ā€œpleat multipliersā€:
AEM: 57.375
PRL: 61.25
And multiplying these by the pleat length, you have roughly:
AEM: 57.375 x 4.205 = 241.26 sq in
PRL: 61.25 x 4.7434 = 290.53 sq in
This does not take into account the curves in the valleys and crests of each pleat which are wider on the AEM, or that the AEM pleats are spaced farther apart, each of which might make for better flow through a single pleat.
Feel free to check my work, but yea the PRL filter has greater surface area and I would guess better flow than the AEM. Does the AEM filter provide better flow than stock? I would presume so.
11th Gen Honda Civic AEM dryflow filter for PRL HVI intake IMG_9460
nattypiso
Dom
Fayetteville, NC
FL5 CW R-05536
I didn’t go deeper into calculating surface area while factoring in pleats, but if you multiply the pleat number by 2 (in and out) and depth you get the following ā€œpleat multipliersā€:
AEM: 57.375
PRL: 61.25
Feel free to check my work, but yea my guess is the PRL has greater surface area.
Appreciate the data! Though it’s barely shorter in height, I think the type of filtration material and design is more important over how much surface area is available. I mean Eventuri’s filter is visually a smaller design compared to PRL’s, yet it still does the job from the testing I’ve seen online.
But for our Type R’s, it has a turbo so I don’t think we would even notice the ā€œrestrictionā€ from that .5 inch difference, since the compressor wheel can spin so fast, it’s gonna get the air it needs regardless of whatever restriction is in front of it.
Maybe for N/A vehicles, there would be a slight difference in performance, but I’m sure there’s some science to it that I don’t know about haha.
timestamped
timestamped
DC
There’s also the 21-209EDK, but definitely won’t fit with the lid on. Seems like only half inch clearance from the lid to the top of the 21-2093DK, it must press up on the PRL filter.
11th Gen Honda Civic AEM dryflow filter for PRL HVI intake IMG_9461
Doskiller
Kevan
Virginia Beach, VA
2023 Civic Type R FL5
AEM: 57.375
PRL: 61.25
Thanks for taking the time to do this. Is this forum great or what ......... ;-)
timestamped
timestamped
DC
Updated ā€œdataā€ with very rough ā€œpleat math,ā€ not that it matters much
  • Like
Reactions: CTR
CTR
strixauto.com
Thanks for all the info and the extra math! Seems like a 17% reduction in flow area which might matter but I doubt it on a boosted application. I think I might pick up the dry flow filter just to reduce the amount of maintenance. I've heard oiled filters can also damage/throw off the MAP sensor.
Have you confirmed if you can remove the AEM filter through the front inlet or do you still need to use the side access?
timestamped
timestamped
DC
I’m dumb, I forgot to test if the filter can actually fit through the front inlet, I was just thinking about whether it could come off the velocity stack. I’m actually skeptical it will fit thru but unfortunately that’ll have to wait a couple weeks til I’m back in town.
