Ferodo pads are good, I have used them on other applications. Just make sure to get the right type of pad for the driving you do. Donāt go to the most aggressive right from the get go.hi all,
Thanks for the recommendations! I have a quick question, are the Ferodo pads problematic on daily driving when the car is cold?
What pads does Honda spec series at the front? Done with the fluid now and after the next track day I will do pads, shims and lines.
The DS3.12's can be a bit noisy for daily driving, but if the OP is looking for a track specific pad, then I'd say the 3.12 is perfect. He'd of course want to swap his factory pads back in after tracking the car.Ferodo pads are good, I have used them on other applications. Just make sure to get the right type of pad for the driving you do. Donāt go to the most aggressive right from the get go.
Yes that is why I mentioned it, depending on the use and how frequently he wants to change pads. I personally like track/street pads since I avoid the hassle.The DS3.12's can be a bit noisy for daily driving, but if the OP is looking for a track specific pad, then I'd say the 3.12 is perfect. He'd of course want to swap his factory pads back in after tracking the car.
What do you like as street and track pads? My wife is not happy that I will be putting on the same track pads on the FL5. And I donāt have the means to keep swapping.Yes that is why I mentioned it, depending on the use and how frequently he wants to change pads. I personally like track/street pads since I avoid the hassle.
Iām using the paragon p3 pads with good results and very street friendly.What do you like as street and track pads? My wife is not happy that I will be putting on the same track pads on the FL5. And I donāt have the means to keep swapping.
Do you use less aggressive pads on the rear?Iām using the paragon p3 pads with good results and very street friendly.
Using stock as of now in the rear, 0 issues. Car feels great and brakes hard with no fade given I donāt push it as hard as @PointByPatrol .Do you use less aggressive pads on the rear?
I use Paragon R5's in the back!Using stock as of now in the rear, 0 issues. Car feels great and brakes hard with no fade given I donāt push it as hard as @PointByPatrol .
Maybe Iāll do the same. I have no gauge on how you two drive and how I drive.Using stock as of now in the rear, 0 issues. Car feels great and brakes hard with no fade given I donāt push it as hard as @PointByPatrol .
They should fit if iām not mistaken.Maybe Iāll do the same. I have no gauge on how you two drive and how I drive.
Does the FK8 front and rear pads fit on the FL5? I have a set left from my FK8 since I traded the car in with track pads on. If they fit then I have 2 sets of stock rear pads to use.
Just saw that Paragon pads are manufactured by Winmax. I used to run their pads on my S2000. Hmmm, will definitely give them a try.They should fit if iām not mistaken.
bumping this up since im looking for a front and rear combo.Iām using the paragon p3 pads with good results and very street friendly.
