Cooling
FL5Luis
Luis
Pennsylvania
2025 Honda Civic Type R
Can someone point me in the right direction for cooling and to help the heat soaking
I added 1/4" spacers (hardware store bronze bushings - in AZ no worries about dissimilar corrosion) between the hood vent and its drip shield, using longer bolts.
I installed the WOT Cooling Plate, exchanging the supplied Allen head fasteners for 6mm x 20 flange head bolts. The Allen heads were fiddly compared to flanged, hex head bolts in my opinion.
I covered the airbox with Thermotech fiberglass backed, self adhesive foil.
IAT's generally lower than before. Zero downsides other than time & money spent.
FL5CW
North America
Did the spacers allow for more heat to exit the hood vent? Curious about this...
AspecR
Stefan
Get an intercooler, Cooling plate and upgraded radiator . If those don't alleviate your concenrs then an oil cooler and turbo cooler should get the job done.
zumbooruk
Ventura CA
I am curious... but could use more details please:
Did you put the spacers only on the two front bolts? or all around?
will these 8mm aluminum spacers work (slightly longer than 1/4" but Prime Day discount...)
https://www.amazon.com/PATIKIL-Aluminum-Spacers-Thickness-Standoff/dp/B0CBJJ2HR2
is this the Thermo-Tec heat shield you used?
https://www.amazon.com/Thermo-Tec-Adhesive-Backed-Aluminized-Barrier/dp/B0844NGHS6
Thanks
