Current infotainment software version? Update issues
powerofdreams
Illinois
2024 Honda Civic Type R
So I was having issues updating my infotainment system awhile back. I tried both the wireless and USB methods and kept getting an error message. The dealer tried to update it unsuccessfully after I took it in, though the update no longer appears after that visit.
Is the current software version 77CA-0055-121? I swear this is the same version that showed when I took it to the dealer, so I just want to make sure the update actually went through. It didn't appear to, though it's possible it completed during the drive home from the dealer.
marcusm86
Marcus
Missouri
2025 Civic Type-R
Mine is always real annoying.. and i got my FL5 in November - doesnt look like i have any update history either.
version status
audio 77CA-0075-121
tcu removed
I also yanked out my TCU, the only way for me to update is via USB, Honda OTA USB Website was giving server errors for a long while, but seems to work now.
My version is 77CA-0068-121 and the Honda site now says says "No updates are available at this time"
CarPlay kept disconnecting, and most of the time, not reconnecting. I set it up for USB only, I also permanently stopped the Honda navigation app, per recommendation on this forum.
Xmetal
CTR, S3
Mine is still showing that I have a corrupted json file? My car is a March 2025 build and the audio version is also 77CA-0068-121
11th Gen Honda Civic Current infotainment software version? Update issues Corrupt
marcusm86
Marcus
Missouri
2025 Civic Type-R
donno if you wanna try to modify that file to see if that fixes it.. i have had 0 luck with that site, but mine is apparently up to date as of may 20th.
Heres what i found -
So i used a different drive and the corrupt file did not have my VIN after the deviceID. But i am getting the connection error with the proper one.. This was failing on a 256GB drive partitioned to only a 30GB Fat32 partition - the rest was empty (no volume made). A 16gb flash drive with no partitions only formatted to FAT32 looks to get the right data.
{"deviceData":{"deviceID": "VIN GOES HERE"
This was with the non-corrupt file
https://www.civicxi.com/forum/threads/spying-on-you.53757/page-12#post-1054616
J_D
J
Montreal
I have nothing to my car except connect to home wifi and search for updates occasionally. Wireless CarPlay works flawlessly.
Xmetal
CTR, S3
Filling in the VIN worked - Thanks for that! I'm getting an "No updates" message now.
Edit: I was using a 32GB drive formatted to FAT32 and the VIN data was missing. I'll try to find a 16GB drive next time to see if all the fields get filled in properly.
11th Gen Honda Civic Current infotainment software version? Update issues NoUpdates
powerofdreams
Illinois
Well, I guess I'll try to check via the USB site again. How long is it supposed to take to download the vehicle info to the USB? I sat in the car for about 20 minutes and it never said it completed downloading. There was a file on the USB (which had the correct space and formatting), but I wasn't able to upload it. I tried with 2 different drives, same thing.
I did factory reset the infotainment, but that didn't bring the update back.
Xmetal
CTR, S3
It should not take more than 30 seconds to get to step 2 as shown in the screen shot below.
BTW, how did you do a factory reset the infotainment?
11th Gen Honda Civic Current infotainment software version? Update issues Step2
powerofdreams
Illinois
Yeah I never made it to step 2.
The factory reset is under system settings.
11th Gen Honda Civic Current infotainment software version? Update issues 1781066873385-66
Xmetal
CTR, S3
It's really odd that all of us is getting different issues/results for mostly trying to doing the same thing under the same firmware/software version :dunno:
powerofdreams
Illinois
So I just tried the USB method again with a different drive and was able to download the file. The USB site said there's no updates. So I guess the version number doesn't actually correspond to the software version? Strange.
