Eibach Pro Kit and/or Sportline Experiences
ElpacoSV
Civic EJ6 ; Civic FK7G4
This is the thing I'm worried about. Honda did some magical things to reduce torque steer and it seems like changing anything from the stock geometry messes with that. When I went to 18" wheels I immediately regretted it. I know some people say they can't feel the difference but I definitely noticed a reduction in handling.
I think you were a strong proponent for sticking with 19" wheels and your feedback has me concerned. I do think the Pro Kit is on the lower side though so maybe there is a happy medium on how much to lower the car (I just purchased Spoon springs).
The saga continues!
If you Had to start all over again, would you go Eibach ou H&R, knowing you drop less with H&R?
Superhatch
Jacob
Wisconsin
So after a few weeks of driving I'm noticing my Pro-kit springs are different heights in the front. Pass side is as expected and looks even with the rear. Drivers side is lower in the front. 2025 with about 4k miles on it.
Measurements from ground to fender lip in front:
Driver: 25 5/16"
Pass: 25 9/16"
I'm really disappointed that they aren't even, and I've probably had a dozen pro-kits for my cars over the years and never had this issue. They are my go to spring.
Not sure what to do really. It's such a PITA to change out the springs I don't really want to do it again.
You can see it here. It's not much but just enough for your eye to notice a difference.
11th Gen Honda Civic Eibach Pro Kit and/or Sportline Experiences 1749317587180-z7
nattypiso
Dom
Fayetteville, NC
FL5 CW R-05536
To be honest, I wouldn’t have noticed until you actually pointed it out. But I sorta had the same experience but with the rear passenger side, but springs ended up settling after driving for about 1k miles, and everything was even all around.
I’m running the more aggressive Sportline-kit (1.2” drop in front, 0.9” rear) and no complaints after over 15k miles.
Superhatch
Jacob
Wisconsin
Ok thanks for responding. I've been driving for a few weeks but not a lot of miles. I'll just keep an eye on it.
nattypiso
Dom
Fayetteville, NC
FL5 CW R-05536
5 days after my post and all of the fenders are at the same height. Total time for full settling was about 3 weeks. Car looks great now.
Glad it worked out ? now is a good time for an alignment if you haven’t done that already.
nattypiso
Dom
Fayetteville, NC
FL5 CW R-05536
Already scheduled!
Nice! Your camber won’t be perfect like it was at factory height, but it’ll be close enough to factory specs once you’re aligned. Nothing to worry about though, it’ll be completely daily drivable and you won’t experience any dramatic tire wear.
sgreer78
St Louis
25 CW CTR
Only about 50 miles on the Pro Kit, but so far so good. Ride is slightly firmer than stock. I do have the ITS shock module, so it may still be softer than comfort on the CTR ADS.
11th Gen Honda Civic Eibach Pro Kit and/or Sportline Experiences 4B62AF2F-E720-45B0-B4CD-B3B0A171EA08
Mawfuqqa
FL5 #9000!!
500 miles on sportlines. Has creaking at front right when angling up a driveway/sometimes slow speed uneven terrain.
Retorqued everything after first 200 miles, did alignment, and sound still exist. Eibach says it's the springs rubbing each other. Asked them if HPDE is a problem sans annoying sound. They said it's fine, will leave as is.
On stock wheels for now. Right around -2 camber all around with the front pins removed.
To me feels like
If stock is comfort/sport/R+
Eibach sport feels like sport/R+/R++
11th Gen Honda Civic Eibach Pro Kit and/or Sportline Experiences IMG_5113
weaponx9x
marcos
miami
nissan sentra
Im running Eibach sportline, car rides like stock, turn is is significantly sharper. No rubbing whatsoever, running 15mm spacers in this setup.
It’s been a while since this post, any updates?? On your set up?
Superhatch
Jacob
Wisconsin
A little over 6 months for me and no complaints. On my winter setup (18x8.5 +38, no spacer) with a winter performance tire. Slightly softer ride, but not a huge difference imo.
Springs are still great, no issues with suspension at all.
11th Gen Honda Civic Eibach Pro Kit and/or Sportline Experiences 1769903754819-ng
Pre winter photo shoot:
11th Gen Honda Civic Eibach Pro Kit and/or Sportline Experiences 1769903781175-9c
11th Gen Honda Civic Eibach Pro Kit and/or Sportline Experiences 1769903811354-o
