Fresh
Northeast Ohio
@Fresh I would chalk that one up to not paying attention to your shifts.
Yeah, my brain probably hit the easy button and forgot to move my foot and only did the hand (half the job). I'm still miffed about it... but it isn't the first time I've done it on a manual... just this car.
First for everything...
Your perfect shift record is now blemished. ? It’s fine
RacingManiac
Jen
Detroit, Michigan
2023 CW CTR R-12374
I just switched from FK8 to FL5. I had my FK8 for 72k miles. Definitely have had a few 1-2 grind and all on autoX use, but they are rare but I am keenly aware of others experiences so I probably take it more deliberate and careful most of the time. That car always had some weird feel going into 2nd, feels "gritty" I guess is the best way to put it. Also has occasional 4th gear lock out for me. From new to when I sold it, behavior never changed. Didn't experiment with different brand of oil though.
FL5 so far, feels exactly the same, aside from I have not yet experienced 4th lock out. 2nd still feels gritty on engagement. I think if you blind fold me and drop me in a car I can't tell you which is which...
Terrell
Kentucky
07 Civic Si
Old thread, I know. But I’ve had 2nd gear grind three times now—two accelerating with some wheel spin (once pulling out into traffic and didn’t see a car coming and had to hurry) and today with mild wheel spin on a wet road. Shifter buzzed in my hand—scared the crap out of me. I still suspect that it’s driver error but not sure I’ve ever had this happen three times in 5k miles on any car I’ve ever had so I google’d it and here I am.
Obviously this isn’t good and ideally would never happen but wanted thoughts here about any long-term damage that may have already occurred.
I found this when searching: “
Yes, I know that sounds strange, but all the gears in a manual transmission are in constant mesh, and what you do when you change gears is slide dog clutches along shafts that lock the various gear combinations.
A dog clutch is just a series of squarish projections on the side of a disk that mates into squarish holes in the matching disk.
So when you get the grinding sound when you miss a gear, it is the dog clutches hitting, not the gears. Dog clutches are VERY tough, so to break one you would need to be very rough, and do this many times.”
No 2nd gear grind here (yet) and I’m approaching 3500 miles
spectre186
Memphis, TN
99 Camry, 23 Civic Type R
No grind here, but I can definitely feel that the car does not like to be rushed shifting from 1st to 2nd. Feels like the synchros take a bit longer on that shift.
abracadaniel_
Daniel
Palmdale
My 1-2 grind happened during my break in period, I had already been driving for a couple hours like a little road trip and once i got to Dana point i was in a section where i had to come to a complete stop and then step on it, so i got on it a little and quick shifted from 1-2 and it grinded on me! other than that i ve had 0 issues about 10k miles later
Terrell
Kentucky
07 Civic Si
Almost exactly how mine happened.
Terrell
Kentucky
07 Civic Si
I have a 2007 Civic Si with a garbage transmission and I shift as fast as I want and have never have had a gear grind ever in 8 years of ownership.
GIChoe
Thomas
NorCal
2024 Civic Si
I've had mine for about 1200 miles and I got some pretty nasty gear grinding going from 1-2. Happened about three times now, and I'm getting kind of worried. It's juuust rare enough that I know the dealer's never going to be able to reproduce it. There's no pattern behind them either; first one was when I was changing gear mid-corner while I was driving slowly. Second time was when I was at about 4k RPM in mild traffic while going straight, and I can't remember the third time.
For reference, I've owned a 2013 FRS, 2016 GTI, and 2024 Si, and none of these ever had any of these issues. The one outlier was the FRS, which would grind going from 4th to 5th and was reproducible enough that the dealer replaced the transmission under warranty.
Terrell
Kentucky
07 Civic Si
Yes, just rare enough they’re not going to be able reproduce it. Also, leaving it with a dealer isn’t something I want.
I am going to keep monitoring and if it continues, something is gonna have to give. I’m not going to pay $44k for a car I’m scared to shift.
GIChoe
Thomas
NorCal
2024 Civic Si
I recall reading somewhere that people had much better experiences after changing the tranny oil to Amsoil...can't remember where though.
Terrell
Kentucky
07 Civic Si
I'd have thought that was crazy, but my Si went from a garbage gearbox to 85% as good as my old BRZs (very underrated box) after changing to new gear oil. So this may be worth trying.
The dealer would love that, though. 'We can't warranty it because you didn't use OEM fluid.'
