keller
Somewhere south
2019 fc3, 2021 fk8
I'm new to here and recently purchased a championchip white fl5. I'm coming from a 19 si full bolt on, ppg gears, ctr clutch / flywheel swap, and a delay valve deleted clutch master cylinder. I'm currently at 330 miles on my new fl5. I've experienced the first to second gear grind four times since I bought it at 6 miles. I don't know if it's me being used to my other setup or the transmission itself or the clutch pedal setup perhaps. It happened the first time at about 28 miles on it. Kind of spread out since then mileage wise.
I found it interesting that I'm not the only one though who noticed this behavior and I never had that issue with my other car.
My wife owns a stock 19 si coupe and I own an fk8. Yes, it's specific to the type R trans. I'm used to it, so I take my time shifting 1-2. On the Si I can upshift a lot faster and never had an issue. Half of my car 2nd gear grinds happened in the very few occasions she was driving it.
Websitesdown
I don't like it. It seriously just makes me wonder if something is off a little pedal adjustment wise or something. Other people are saying it never happens to them which is odd..
I'm sure that some of the people that're saying it never happens to them, can shift as fast as us. I find it very odd..
keller
Somewhere south
2019 fc3, 2021 fk8
Integra23
2023 Integra 6spd A-Spec
I have adjusted the pedal but I still had a grind. Next steps is fluid change.
Getting into 2nd is never smooth and feels clunky also the engine rev matches kind weird going 1st to 2nd.
Terrell
Kentucky
07 Civic Si
I’m trying the pedal adjustment, the fluid, and then a rear engine mount. If that doesn’t fix it, I’m selling it. I’m not driving a sports car—never mind a Type R—that every time I shift into second I’m scared of grinding a gear. It’s just not an enjoyable driving experience.
Bigfx
2024 civic type r
You know you could try the dealer.
Terrell
Kentucky
07 Civic Si
As far as I can tell, this hasn’t been successful for a lot of people. Drop off your car, they call you 48 hours later saying they can’t reproduce the issue, etc.
fredzy
PA
Sienna, GR86, TourX
Yeah at best they would do the clutch pedal adjustment, so go for it and see.
Quick questions for folks that get grinds often - is it usually when the trans is cold? Or will it do it after you've been driving a while and doesn't matter about gear oil temp?
I've never gotten a grind but 1-2 and 2-3 can be a little notchier than I like when the car is cold. (Manual trans - what else is new!?) The Type R takes a little longer to loosen up than most cars I'm used to.
xpeng
I only have 500 miles on my FL5. I do feel 2nd and reverse are not as smooth as others. I did have grind at least once. So I always pull harder when switching to these two gears.
FL5golfer
Paul
SoCal
I don't grind anymore after adjusting my shifting speed and smoothness. Clutch in all the way to the floor, let the RPM's drop, and clutch out, add gas. Being smooth is the key.
Keep in mind the trans needs some break-in time. Things are tight from the factory, which is to be expected. Give it time and mileage (heat and cooling cycles). It doesn’t sound like a regular enough occurrence to be of concern especially as your car is so new. It should settle-in within 2k-3k miles depending on driving habits.
Yes. 2nd and Reverse require more “deliberate” action. You should never have to muscle it, but it can require more than a flick of the wrist sometimes (particularly when cold).
Terrell
Kentucky
07 Civic Si
I’ve never, ever owned a car in my life that would grind if I didn’t shift slowly or wait until it’s warm or use a certain number of fingers or purposefully or some magic way. You should shift correctly and the car should change gears. I’ve probably owned 30+ cars and have never had this be a problem, which sucks because my CTR is otherwise the best car I’ve ever owned.
