Inlet pipes with stock airbox?
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
Does the PRL inlet make any difference in sounds? Or is it purely eye candy lol
The Eventuri turbo inlet pipe also works with the stock air box. Here is a link with PICs. I decided to go with it because it is a one piece unit, has the largest internal ID, and allows for the use of other aftermarket intakes.
IMHO, the OEM inlet pipe is an aesthetically eye pleasing 5+ pound heat sink.
Infinity Design also sells a one piece turbo inlet and intake kit that looks good. Here is a link to that thread.
GIChoe
GIChoe
Thomas
NorCal
2024 Civic Si
Yall are amazing, thank you
FYI, I just got the Cobb Redline Carbon Fiber Intake from @JST Performance
I asked them about turbo inlet recommendation. their response was:
I would just use the stock inlet personally. Which is what i do on my car. The stock FL5 inlet is great.
but prior to the above, I was attempting to research and decide between the Eventury and Infinity Design
I was leaning toward the Infinity Design.
for now, I decided to skip the turbo inlet and just go with Cobb AP/Jailbreak/Tune and the Cobb intake
That's sound advice. Skip it.
champ_white_FL5
Jim
New Mexico
2024 civic type r
Commenting to confirm fitment with the PRL carbon inlet. This inlet was bought brand new from TSP and came with the hoses for the HVI. So the newer inlets that are only compatible with the HVI work with the OEM air box and accordion hose.
11th Gen Honda Civic Inlet pipes with stock airbox? PXL_20251205_200055627
champ_white_FL5
Jim
New Mexico
2024 civic type r
Adding that you can use the tube from the stage 1 intake as well. I prefer this setup as it looks cleaner and you don't have to "stretch" the accordion hose as much. It's a bit finicky to get all the hoses right, but fits nicely once you do. Not rubbing or gaps. The turbo noises are a bit louder compared to OEM, so that's a nice bonus!
11th Gen Honda Civic Inlet pipes with stock airbox? PXL_20251213_192143311
11th Gen Honda Civic Inlet pipes with stock airbox? PXL_20251213_192147431
champ_white_FL5
Jim
New Mexico
2024 civic type r
I've owned oiled filters on my prior cars and I don't want to do the cleaning and maintenance for those. I'm happy with my aFe dry drop-in filter, but I would like to get a nice inlet pipe for the aesthetics.
How is the AFE dry drop in? I've had my eye on it for a bit. Does it have a decent amount of surface area compared to the OEM? I know k&n's are a lot thinner and have less pleats meaning less surface area than the OEM paper filter. Curious how the AFE is.
Also, is there any added turbo noise with just the AFE dry drop in?
Blindeye_03
Cincinnati Ohio
'24 CTR - red
was wondering the same thing and if theres a part number? All I can find is the one you have to oil.
champ_white_FL5
Jim
New Mexico
2024 civic type r
Happy thanksgiving everyone! Quick question: are there any turbo inlet pipes that work with the stock FL5 airbox? I don't want to upgrade my intake, but I do want to remove the stock baffled turbo inlet pipe. Thanks in advance.
Did you ever decide on an inlet pipe to pair with the OEM box?
GIChoe
GIChoe
Thomas
NorCal
2024 Civic Si
Nope, I went to a couple track days and decided to focus on beefing up my braking system. Bought some girodiscs, Project Mu pads, and changed the fluid to DOT4.
champ_white_FL5
Jim
New Mexico
2024 civic type r
How is the AFE dry filter? Does it add any noticeable induction noise or throttle response?
