I have just a 25 dollar AD310 that i used to use to read stuffs on my 09 corolla laying around. Ended up ordering the autel and read it again and nothing showed up. Now i gotta take the car to the dealer because these is a whining sound only in second gear.is it not visible with a normal code reader?
some gear whine is normal. also the a/c compressor can make a faint whining noise, especially at low load. do you have a video/sound clip of the noise? maybe we can tell you if it's normal or not.I have just a 25 dollar AD310 that i used to use to read stuffs on my 09 corolla laying around. Ended up ordering the autel and read it again and nothing showed up. Now i gotta take the car to the dealer because these is a whining sound only in second gear.
Imma try that, it might be in all gear but most noticable in 2nd as speed is low enough and rpm is low enough getting out of the neighborhood. 1st gear RPM too high to hear maybe, but starting 3rd road noise take over. Imma try to record next time i get in the car.some gear whine is normal. also the a/c compressor can make a faint whining noise, especially at low load. do you have a video/sound clip of the noise? maybe we can tell you if it's normal or not.
Any update on your issue? Did you have the overrev code?Imma try that, it might be in all gear but most noticable in 2nd as speed is low enough and rpm is low enough getting out of the neighborhood. 1st gear RPM too high to hear maybe, but starting 3rd road noise take over. Imma try to record next time i get in the car.
No over rev code as far as I can see.Any update on your issue? Did you have the overrev code?
But it still have a faint noise in second.Any update on your issue? Did you have the overrev code?
If you have an aftermarket RMM then some increased NVH is normal. Also, if you're on OEM fluid or anything that's low viscosity, the trans noise will be louder.But it still have a faint noise in second.
Everything oem, just over 4000 miles on the Odo.If you have an aftermarket RMM then some increased NVH is normal. Also, if you're on OEM fluid or anything that's low viscosity, the trans noise will be louder.
It's probably just normal gear wine. Put some fresh Honda MTF in there and see if it goes away.Everything oem, just over 4000 miles on the Odo.
This have been around 600 ish miles. but the thing is i dont know if its normal or not, i have not driven another stock type R.It's probably just normal gear wine. Put some fresh Honda MTF in there and see if it goes away.
